1981 CJ-7 w/ 4 speed SR4 tranny. broken - JeepForum.com
post #1 of 5 Old 06-22-2012, 09:36 AM Thread Starter
JupiterFLCJ7
1981 CJ7
Help! When I shift into reverse and let off the clutch the shifters jumps into neutral, my buddies tell me I need a new transmission. I want to upgrade now if it makes sense and also add 33" tires and new gears. Should I try to find a tranny at a junk yard? What model should I get? The t4 and t5 are labeled light duty, is there a heavier duty that would work? Also, my bud says a t4 or t5 will be $1,500.
I plan on off-roading and light mudding. Im in FL so sand and mud is all we have.
JupiterFLCJ7 is offline
post #2 of 5 Old 06-22-2012, 10:16 AM
Dubl0Vert
fORD T-18s always sound good to me. they are available in junkyards and advanced adapters has the parts to make it fit. Personally, I pick up t-5s for 150-300$ and run'em till they pop. I'm on my third and its the best by far, must have been rebuilt at some point.
Regardless, get driveshafts that match the tranny, that way you don't have to cut and weld yours.
1984 CJ7 -- 258/5-speed
Nuttered and Rushed
Carter is the BBD
Dubl0Vert is offline
post #3 of 5 Old 06-22-2012, 11:19 AM
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
Find a T-176. Best 4-speed Jeep ever used.
T-18's are strong, but they are basically a 3-speed that has a granny gear. They are clunky shifting and just aren't as good a trans to use on the street as the others.
For off-roading and light mudding, you really don't need the strength of the T-18. T-176 will handle it easily, and be better on the street.
I asked a ref if he could give me a technical foul for thinking bad things about him. He said, of course not. I said, well, I think you stink. And he gave me a technical. You can't trust em. -
Jimmy V
Pacfanweb is offline
post #4 of 5 Old 06-22-2012, 11:23 AM
80cj
80cj's Avatar
1980 CJ5
X2. T-176/T-177 have decent strength (will handle a 360 V-8) and have good intermmediate ratios.
80cj is online now
post #5 of 5 Old 06-22-2012, 12:39 PM Thread Starter
JupiterFLCJ7
1981 CJ7
thanks y'all that was fast, Im looking for t-176
cj-7 , driveline , jeep , shift , transmission
3 speed tranny????? 78treehugger Jeep CJ Forum 6 12-11-2008 12:05 AM
What 4 speed tranny will fit a cj 5 summitking Jeep CJ Forum 5 05-31-2008 12:53 PM
85 CJ7 5 speed tranny ISurvivedNMU Jeep CJ Forum 8 07-25-2006 06:55 AM
Broken Tranny BESRK Jeep CJ Forum 3 11-13-2005 08:43 PM
5-speed tranny in CJs??? buckallred Jeep CJ Forum 5 07-16-2004 10:03 AM
