Originally Posted by dtrimble
I want to swap out a 258 and put in a 304. can anyone tell me if its hard to do??? Can I use anything from the 258 like the altinator or Air conditioner?? Will the 304 bolt in with no problems?? Do i have to get a new trans?? Im guessing I have to get new motor mounts. If anyone has done this please help me out
belhousing , clutch, flywheel, starter, altenator, radiator, are all the same... simply bolts up... you will need all the brakets for the 304 since the one's for the 258 won't work (altenator braket etc.. )
i was doing the 304 to 258 swap.. ti'll i ran into a running cj-7 with the 258 in it... swaping from the 258 and going to a 304 isn't really hard it's more like expensive if you don't have a running donor vehicle... all parts are available online ( for a price ) i found i was cheaper to buy a donor than to buy what i needed online
i would forget about AMC and go with a Chevy drive train ( from a donor vehicle) ... it's cheaper in the short and long run, plus chevy parts are everywhere... that's my 2 cents
