1980 CJ7 1" Body Lift - JeepForum.com
post #1 of 6 Old 08-15-2013, 06:35 AM Thread Starter
AtlantaCJ7
1980 CJ7
Morning all, thinking about adding a 1" body lift...I am putting a 2.5" BDS lift in now, and just thinking through how to put the 1" body lift on. I have heard not to do more than a 1" BL, but wasnt sure if even 1" would create issues like brake lines, drive shaft, fan shroud, or transfer case. Any thoughts, advice? What is the easiest way to lift the tub in my garage? I also have a forklift at my office...maybe that would be easier? I am running 33x12.5 on 15 x 8 stock wheels. thanks!
AtlantaCJ7 is offline
post #2 of 6 Old 08-15-2013, 02:14 PM
bigjoe
1977 CJ7
I'm running 1" on my 77' CJ7 only issue I had was I needed to extend the shift linkage on the auto tranny. No issue with tire stuffing in wheel wells but I'm only running 31" tires on that Jeep.
Seems like everyday is a Monday.
77' CJ-7 83' Chevy K10
bigjoe is offline
post #3 of 6 Old 08-15-2013, 02:36 PM
LumpyGrits
YES, on fan shroud clearance issues.
I just lowered my radiator 1 inch is all.
Watch the fuel tank filler/overflow hoses and the angle of the clutch bellcrank angle. It must remain horizontal.
Also check to be sure that NONE of your brake lines are now rubbing against the body at any point.
LG
LumpyGrits is online now
post #4 of 6 Old 08-15-2013, 03:29 PM
GP_Pete
GP_Pete's Avatar
LG
^ this. Not hard. Just drill new holes for radiator support bolts. Be sure to soak your old bolts in penetrating oil for a few times before starting. Those old body mount bolts suck.
AMC 360
GP_Pete is offline
post #5 of 6 Old 08-15-2013, 03:49 PM
arkiemurph
One plus is it's easier to get to some stuff and to wash out your undercarriage. Example: I'm fixing to change my gas lines out in the back. With the body lift, I can get to them without dropping the tank!
Murph
Love thy neighbor, but don't mow down the hedge.
arkiemurph is offline
post #6 of 6 Old 08-15-2013, 04:01 PM
LumpyGrits
Murph
DANG, you must have small hands......
LG
