1980 CJ5 return fuel line re-routing, issues w/ pass. side? - JeepForum.com
post #1 of 3 Old 03-27-2013, 10:04 PM Thread Starter
EgulAye
1980 CJ5
I've just started getting a very tired CJ5 to run, and have a leaky return fuel line to replace. My thoughts are to re-locate the line from the driver's side to the passenger side of the Jeep and away from the exhaust. With the existing leaks fuel is dripping on the exhaust. Obviously a new line will correct that issue, but it seems like a good idea to me to ovoid this potential issue in the future by moving it.
Is there any reason I shouldn't move the fuel line or any gotchas that cause problems when re-locating the return fuel line? I could take the easy way out and just rubber hose over the valve cover and then follow the fuel supply line down the passenger side of the frame. Or I could probably find an alternate location a little further back that doesn't go over the top of the motor.
Does anyone have thoughts or prior experience on this?
Thanks
EgulAye is offline
post #2 of 3 Old 03-28-2013, 03:15 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Well I wouldn't use rubber tubing over the engine. It could dry out and crack from the engine heat. Use hard line until you reach a point were it needs to flex.
I uses Stainless steel for a return line on the driver side. Will probably last longer than me.
John Strenk is offline
post #3 of 3 Old 03-28-2013, 03:21 AM
BagusJeep
1981 CJ7
If you follow the bulkhead you can do it in Tube all the way, just have to get it lower than the fuel filter along the bulkhead so it drains nicely. The only piece of Hose should be the final connection to the filter, for maintenance, and at the tank. You will have to deal with the flexing of the engine on its mounts so the Tube should be fastened to the bulkhead and then run free the couple of feet to the filter. If you make it from one piece of Tube no leak issues. The steel line is less than $20 in bulk.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
258 , cj5 , fuel return line , straight six
