1980 cj5 chevy 350 tbi swap issues - Page 2 - JeepForum.com
post #16 of 30 Old 12-26-2013, 02:24 PM Thread Starter
tmclmc
1980 CJ5
This is to 1986 Cj
Did you have to get custom axel shafts and how was the instalation and mount of the chevy tranny in the jeep frame I'm guessing custom brackets?
tmclmc is offline
post #17 of 30 Old 12-26-2013, 02:32 PM
dg6772
Mine uses the stock trans mount for an automatic. I had to drill new holes for the bolts,that's all. Not sure if this method will work for you,but I'm guessing it should.
I did have to change drive shaft length. I'm guessing that's your question.......not custom axles
Dave in Muskegon
dg6772 is offline
post #18 of 30 Old 12-26-2013, 04:31 PM Thread Starter
tmclmc
1980 CJ5
So the flywheel was actually to thick like a 1 1/2 inches to thick my guy screwed it up I guess but he is fixing and getting my the right parts
tmclmc is offline
post #19 of 30 Old 12-26-2013, 04:37 PM Thread Starter
tmclmc
1980 CJ5
Yea man sorry ment drive shafts
tmclmc is offline
post #20 of 30 Old 12-26-2013, 04:46 PM
dg6772
Glad to see you got to the bottom of the issue.....
Dave in Muskegon
dg6772 is offline
post #21 of 30 Old 12-26-2013, 04:50 PM
dg6772
I've never heard of a flywheel that thick though......hmm, I thought that most G.M. flywheels were the same,other than diameter and tooth count.
Dave in Muskegon
dg6772 is offline
post #22 of 30 Old 12-26-2013, 05:18 PM Thread Starter
tmclmc
1980 CJ5
Idk man it is weird never seen it either thanks for the help
tmclmc is offline
post #23 of 30 Old 12-26-2013, 05:29 PM
dg6772
No problem. That's what we all do here.
Dave in Muskegon
dg6772 is offline
post #24 of 30 Old 12-27-2013, 11:44 AM Thread Starter
tmclmc
1980 CJ5
So another couple questions
How difficult is it to do spring over and what do I need or should I just try to upgrade the exles to bigger ones and the other is is it possible to delete the p/s pump and if so how
tmclmc is offline
post #25 of 30 Old 12-27-2013, 11:50 AM
dg6772
I don't know much on the soa conversion but to get rid of the p/s pump you will need a manual steering box.
Dave in Muskegon
dg6772 is offline
post #26 of 30 Old 12-28-2013, 11:33 AM Thread Starter
tmclmc
1980 CJ5
My jeep came with Manuel steering but the chevy 350 came with power steering idk if just getting a shorter v belt would do it or not
tmclmc is offline
post #27 of 30 Old 12-28-2013, 01:05 PM
dg6772
If you in fact have ( V ) belts,then you can get one for a 350 without power steering. The power steering belt was usually a stand alone belt.
Dave in Muskegon
dg6772 is offline
post #28 of 30 Old 12-29-2013, 06:07 PM Thread Starter
tmclmc
1980 CJ5
Well it's out of a 93 chevy that's av belt correct
tmclmc is offline
post #29 of 30 Old 12-29-2013, 06:11 PM
dg6772
Mine is a serpentine belt. One belt for all accessories.
Dave in Muskegon
dg6772 is offline
post #30 of 30 Old 12-30-2013, 05:23 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Wonder if maybe it was an 11" disk/PP inside a small bellhousing intended for a 10.5" clutch?
Also, you mentioned the broken input shaft sleeve.. that's what the throwout bearing rides on. Depending on the damage, it may still be able to be used.
BESRK is offline
