1980 CJ 5 Lift Kit - JeepForum.com
post #1 of 7 Old 08-19-2007, 02:45 PM Thread Starter
SCHUSKER
1980 CJ5
1980 CJ 5 Lift Kit
Has anyone installed a 2.5" Rough Country Lift kit on a CJ5? Doing all the work myself, started on the front drivers side, everything fit great. Next started on the rear drivers side. The supplied leaf spring (part no. 8008) doesen't seem to be long enough. contacted Rough Country, they said to try and bolt the leaf spring to the axle first, then attach it to the mounts. Tried this all day with no results, lack about a quarter of an inch from getting the bolt through the mount. What am i doing wrong?
SCHUSKER is offline
post #2 of 7 Old 08-19-2007, 03:15 PM
supraman1990
supraman1990's Avatar
1980 CJ5
Sure your using the rear spring? Dumb question, but it happens.
80 CJ5 in the process of a frame up resto
96% complete.
The little stuff will kill me.
On the back burner for college.
supraman1990 is offline
post #3 of 7 Old 08-19-2007, 03:30 PM Thread Starter
SCHUSKER
1980 CJ5
Yep, triple checked
SCHUSKER is offline
post #4 of 7 Old 08-20-2007, 07:53 AM
imafishingfred
imafishingfred's Avatar
1981 CJ7
My son had a problem with his also (not the same lift you have). His were to short. We simply put a rachet strap around the frame and axle and preloaded the spring as if it had lots of weight on it. The spring flattend out enough to get the bolts in.
imafishingfred is offline
post #5 of 7 Old 08-20-2007, 11:22 AM
GasAxe
GasAxe's Avatar
1983 CJ5
I'd measure the length of the spring, then call RC and make them tell you what length the spring is supposed to be. Don't tell them what you have first or they can just say "Oh yeah, that's the right one".
Seems to me that if you have to preload the leaf spring, that may be why RC has a reputation of a stiff, harsh ride.
Marching or fighting, it all pays the same.
Originally Posted by jeep-jeep-01
And by the look of his avatar and name... not a hippie.
GasAxe is offline
post #6 of 7 Old 08-24-2007, 01:19 PM Thread Starter
SCHUSKER
1980 CJ5
As a follow up, I finally got the spring into place. I put my floor jack under the sping and kept jacking until I could take a crowbar and pry it to where I could insert the bolt. If you ever buy this kit throw away the instructions, there worthless.
SCHUSKER is offline
post #7 of 7 Old 12-26-2009, 01:04 AM
Nitro1
1982 CJ7
How does it ride?
Nitro1 is offline
1980 cj5 1" body lift problem LSUtiger Jeep CJ Forum 9 12-19-2009 10:02 AM
4.0 HO or 5.2 in a 1980 CJ7 bigpoppavtx Jeep CJ Forum 5 09-26-2009 04:24 PM
1980 cj5 harmonjr Jeep CJ Forum 1 07-07-2007 07:56 AM
What lift is needed to fit 36-38 inch tires a 1980 cj 7? jeepcj7 Jeep CJ Forum 5 01-18-2003 07:42 PM
Is there a 6 inch lift out there, for a cj 7 1980? What is the best overall lift? jeepcj7 Jeep CJ Forum 13 01-18-2003 10:46 AM
