1979 Jeep CJ5 - JeepForum.com
post #1 of 6 Old 04-06-2005, 06:46 AM Thread Starter
mustangdave357
1979 Jeep CJ5
Hello, I have the opportunity to buy a 1979 Jeep CJ5 with the AMC 304 V8 Engine. The jeep has been sititng for 5 years untouched. When it was parked it ran perfectly and had no problems. 5 Years later I am not sure what I might be getting into. Is the 304 a good engine? What do you think the jeep is worth, the guy is asking $500.00. What things can I expect to get into by buying this, thanks, Dave
mustangdave357 is offline
post #2 of 6 Old 04-06-2005, 07:11 AM
dawgates
1980 CJ7
500 bucks??? Where's the Jeep located? If you don't buy it someone else will and fast! I'll buy it if you pass it by.
The 304 is a great engine. It's very under rated. It's a good comparson with the small block Chevy.
As far as what to expect? What do you want to do with it? The sky is the limit as to what you can do with the Jeep.
Just make sure you change the oil/filter, check all the fluids before you start the engine. Take a can of WD40 and shoot a little in each spark plug hole for some needed lube. The cylinders have to dry after 5 years of sitting.
Good luck and keeps us informed.
80' CJ7, 360 Howell Injected, 3" single exhaust, NP435 4spd, Dana 300 AA clocking ring, Currie twin stick, Tera-Low 4 -1 kit, Dana 44 front, cut 10" wider to 63", 4.10 gears, ARB, Yukon axles and Super H/D u-joints, Currie Dana 44 rear, cut wider to 60 1/2", 4.10 gears, ARB 35 spline, Currie 35 spline axle shafts, 2 1/2" x 11" Ford drum brakes, CJ-SOA conversion, Tom Woods F & R drive shafts, Warn 9500i winch, 6 point cage, Homemade F&R bumpers and tire carrier, 1" body, Pro Comp supension Kit, 12.5x35x15 BFG's, 15x10 OMF beadlocks, Body armor, OBA.
dawgates is offline
post #3 of 6 Old 04-06-2005, 07:15 AM Thread Starter
mustangdave357
Thats some good info, I will probably buy it I just didnt know what to expect of a vehicles condition after sitting for 5 years. The WD 40 is a good idea, any others, I am sure the gas is bad, what else would be good to do before I start it, thanks again!!!
post #4 of 6 Old 04-06-2005, 07:41 AM
gunkysputter23
Manual Fuel pump could be dried and rotted. Cooling system could have massive amounts of corrosion. Fuel system is probably rusted pretty bad. Make sure the wires haven't been chewed up by mice & rats. Check the carb, intake manifold and cylinders for dirt dobber wasps' nests, if you have this little critters in your area. There's lots more which I'm sure others will add. Lastly, expect to spend every penny you make on her for the next several months? years? Hell, go rob a bank and it'll be affordable.
I've been pumping my baby with dough for years now. At my last calculation I figure she still needs about 4-5 grand put into her. And thats just for materials, I do my own labor.
gunkysputter23 is offline
post #5 of 6 Old 04-06-2005, 08:17 AM
dawgates
1980 CJ7
4-5 grand!!! gunkysputter23 you cheap skate, you're hold back. I beat I have double that in mine and I also do my own work.
You need to dig deeper into those shallow pockets.
Like a wife or girlfriend "tit's and tires", a Jeep is a money grabber.
I wouldn't be surprised if my Jeep sneaks into my wallet at night and take a few bucks out when I'm asleep. Everytime I turn around it's asking for M.O.R.E.!
dawgates is offline
post #6 of 6 Old 04-06-2005, 09:35 AM
gunkysputter23
I've been trying not to hold back. 4-5 grand will get her to where I want for now. I figure I've already put about 17 grand into her (including initial purchase cost) and will eventually put another 10-15 in. That or just get another CJ or two and start all over again, but this time do some things differently. I've a 78 Chevy 350 Pickup running but ready to be parted out (in several years) and will probably use the ol trucks engine,tranny,xfer & axles for my next project after the two I currently have going are finished.
1979 Jeep CJ5 (just a picture, no tech.) mmerlina Jeep CJ Forum 20 05-15-2009 02:09 PM
1979 Jeep Cj5 Bikini Top kcarlsonjeep Jeep CJ Forum 2 04-13-2009 03:37 AM
1979 CJ7 Jeep 6 Cylinder ? dtrdaniel Jeep CJ Forum 3 04-02-2008 09:17 PM
Anyone with a 1979 Jeep CJ *Thunder Jeep CJ Forum 3 01-10-2008 11:52 PM
1979 Jeep CJ7 half top jpnkavu Jeep CJ Forum 4 10-11-2006 05:37 PM
