1979 CJ7 Dash Lights arent working - JeepForum.com
post #1 of 3 Old 09-17-2008, 07:08 PM Thread Starter
hookntail
1979 CJ7
I just purchase a 79 CJ7 and none of the dash lights are working. I took a hot wire and hooked it up to the headlight indicator switch and it came on with power. Obvioulsey, none of them are getting power. Icant trace back the power wire for the dash lights. Any thoughts? Also, my horn wont work from the wheel. I put power to it under the hood and it sounded. Also, my passenger sided turn signal indicator in the spedo cluster is staying lit. The pasenger side fron marker light is very dim. is this coincidenc or relay or something.
thanks
steve
hookntail is offline
post #2 of 3 Old 09-17-2008, 07:15 PM
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
Welcome to the Jeep world$$$$$ first off Have you tried turning the light switch knob to make your light work, not sure if you are aware of that or not. the speedo blinker light on mine stays solid when I have a bad bulb. The horn sounds like a broken connection somewhere, not for sure.
United States of America
Born: July 4, 1776
Died: Nov 4, 2008
SUICIDE
SlikRic is offline
post #3 of 3 Old 09-17-2008, 08:11 PM
Renegade79
i had a similar problem as you with my speedo cluster. all of my lights were burnt out so that was the first problem and then i have to play with turning the light switch left and right to get the speedo lights to work. once i find a good spot they stay on fine, but it had me a little perplexed at first.
congrats on gettin a jeep and a 79 at that!
'06 Wrangler SE, soft top, hard doors, 2.4L, rolling completely stock and unmodified for the short term...
'10 Wrangler Sport, soft top, hard doors, 23S package, Teraflex 2.5" spring lift, Spidertrax 1.5" wheel spacers. Sold.
'79 CJ-7 Renegade, 258 I6, T150, D20, D30/AMC20, 2.5in Rancho lift, 31x10.5 AT's, TeamRush upgrade, flush tail lights - Sold :'(
Renegade79 is offline
Dash lights not working in 77 CJ7?? Brownstone77 Jeep CJ Forum 3 10-07-2009 01:57 PM
Dash lights quit working. scottymac62 Jeep CJ Forum 9 06-02-2009 09:24 PM
high beam light working but no other dash lights threefortheshow Jeep CJ Forum 9 11-27-2008 07:18 PM
Dash indicator lights not working onesourcemike Jeep CJ Forum 4 08-11-2008 07:58 AM
dash lights not working. jlutsey Jeep CJ Forum 2 05-08-2007 07:29 PM
