1979 CJ7 258 EGR VALVE OEM #'s missing - JeepForum.com
post #1 of 6 Old 03-13-2010, 01:43 PM Thread Starter
paashla
Does anyone know how to determine what EGR valve you need when the OEM #'s are missing from the sticker on front of the EGR valve. I pulled it off and there are no #'s anywhere. Trying to get it smogged in california and the EGR came up bad, no problem went to NAPA and they said there is three to choose from and I will need the OEM # - HELP!
paashla is offline
post #2 of 6 Old 03-13-2010, 02:17 PM
scottymac62
1979 CJ7
The Jeep part # is J324 0187 for a California EGR for a 258. See if NAPA can cross the number for you. Or call your local Jeep dealership and see how much they will take from you.
'77 CJ-5 Renegade 304 / T-150, Dana 20, 30/20 axles, Aussie Locker in the Dana 30, American Racing 15x10 Outlaw II's, 33" Dynapro M/T's" ,Optima Battery, TeamRushed + Summit Racing CDI ignition, FlowKooler water pump, Edelbrock Performer Intake Manifold, Holley 4160 390cfm, Herculiner, Silver Ceramic Coated Hedman Hedders, Flowmaster 40's.
Warn PowerPlant HD 12K Winch, Dirtworx front and rear bumpers.
scottymac62 is offline
post #3 of 6 Old 03-13-2010, 04:34 PM Thread Starter
paashla
Thank you for a quick reply, but I have a part 2
While I was trying to investigate which EGR I needed, I kept running into Automatic or Manual. Mine is a Manual 3 speed. Will this be a determining point in the J324 0187 choice?
Thanks,
Steve
paashla is offline
post #4 of 6 Old 03-14-2010, 08:29 AM
scottymac62
1979 CJ7
Thanks,
Steve
Yes, J324 0187 is for the manual transmission (California) EGR. There are about 7 different part numbers for the ERG's in the CJ parts manual, but this is the one that is for your application.
post #5 of 6 Old 03-14-2010, 10:59 AM Thread Starter
paashla
Just wanted to say "Thank You".
paashla is offline
post #6 of 6 Old 03-14-2010, 12:13 PM
scottymac62
1979 CJ7
You are very welcome!
1979 CJ7 258 6 cyl valve cover question jpnkavu Jeep CJ Forum 3 10-02-2015 02:18 PM
Missing coolant; yellow-white goop under valve cover obscurotron Jeep CJ Forum 4 02-16-2010 03:29 PM
258 No compression, Valve Cover off, What's missing? whittlecj Jeep CJ Forum 63 02-04-2009 10:09 PM
Valve cover replacement (am i missing a bolt somewhere???) valkadesh Jeep CJ Forum 7 07-23-2007 02:28 PM
1979 CJ7 258 6 cyk valve cover question jpnkavu Jeep CJ Forum 2 03-20-2007 10:39 PM
