1979 CJ5 Frame Up Restoration - JeepForum.com
post #1 of 4 Old 02-21-2003, 03:11 PM Thread Starter
cyoungone
Question 1979 CJ5 Frame Up Restoration
I have started the restoration and could use some opinions. I am working on my third restoration of a 1979 CJ5 and have decided to go all the way this time. The time has come to replace the body tub on the Jeep and I would like to change fro steel to fiberglass. What are the pros and cons of doing this and where should I look for a new tub and get a good deal?
cyoungone is offline
post #2 of 4 Old 02-21-2003, 03:57 PM
clegger
Have you ever thought about an aluminum tub? JP makes a nice one. I think about $2500, but not sure.
78' CJ-5 in process of frame off, 84' V8 Ranger
clegger is offline
post #3 of 4 Old 02-21-2003, 06:32 PM
Wildbill
Wildbill's Avatar
Fiberglass Tubs....
I did a restore several years ago on a '79 CJ-5 and used a 4WD Hardware F/G Tub. It seems well built but I did not like the fact that I had to measure and scribe all the holes in the firewall and floor boards. Also I did all the prep work on the tub before painting and all the fiberglass dust is a bit*h.
If you decide on doing the F/G tub take my advise and replace ALL of the body. I thought I could fix the rust in the fenders and re-use them and now I wish I had spent the extra 250 to 300 bucks for the fiberglass ones.
Wildbill
Yale H.
Club President
Peace River Jeepers
Blue Jeep Club Member #23
'92 Blue YJ 4.0 HO, 5spd.
'04 Bright Silver Liberty Sport 4X4 3.7L Stock for now
What do a Divorce in Alabama, A Tornado in Kansas and a Hurricane in Florida all have in common?.....No matter what someone is fixin' to lose a trailer
Wildbill is offline
post #4 of 4 Old 02-22-2003, 08:30 PM
mxg342
mxg342's Avatar
Fiberglass is pretty nice. It will never rust!!! Granted the dust is a pain to work with but if you make a mistake that's nothing that tigerhair and putty can't fix. As for marking the holes for the heater and everything here is an easy fix. (yes I use the term easy loosely)
Carefully cut the firewall out of the metal body. Them take sheet metal screws and attach it to the fiberglass firewall. Now you can just drill the hole to the exact size and location and everything lines up fairly well that way.
Oh and as far as bodies. Expect to spend 2000-2500 on a glass body. Some are better than others of course. 4WD makes a nice one and so does AJ's. With the AJ's body they will put the color in the gel coat so no need to paint it!!! that's a plus!
HTH
'84 CJ-7 Junkyard TBI 360/T18/D300, 4" 4WDH Lift, D44 front with ARB and HS/D44 Rear w/ Detroit, 4.56s, 36" Iroks, TFI, TJ flares, Homemade rocker guards and bumpers with swing out, Optima Yellow Top, M8000, York OBA, 6pt cage
"when you're up to your *** in alligators, it is hard to remember that your original intention is to drain the swamp"
mxg342 is offline
74' CJ-6 frame off restoration djui5 Jeep CJ Forum 35 06-02-2013 06:26 PM
Frame off restoration jmna Jeep CJ Forum 12 12-22-2008 02:00 PM
Frame restoration andresesquire Jeep CJ Forum 2 11-05-2007 06:54 PM
More photos 1979 Restoration Project cj7roaddog Jeep CJ Forum 11 08-18-2007 07:05 PM
1979 CJ7 Restoration Project (COMPLETE) jpnkavu Jeep CJ Forum 13 05-15-2007 11:26 AM
