1979 CJ5 Build (Tank Killer) - Page 7 - JeepForum.com
 1Likes
post #91 of 1283 Old 04-12-2011, 11:46 AM Thread Starter
boarderofsnow
1979 CJ5
Next came welding the bumper on. I didn't mention above but we removed the gas tank for safety with the welding. Just common sense. I took this opportunity to take picture because I am planning on going with a custom gas tank set up in the rear. Most people just slap a gas tank in the back seat but owning a CJ5 means you already have as little room as possible.
So here is the bumper welded up and then pictures for the inside of the rear frame rails and crossmember.
boarderofsnow is online now
post #92 of 1283 Old 04-12-2011, 11:54 AM Thread Starter
boarderofsnow
1979 CJ5
Next was welding up the rear hangers. We knew we would only be able to weld into the outside of the hangers because of my exhaust location and there hangers would be perment (unlike my front hangers when I go to full width axles) so we drilled into the frame and added two bolts to the underside of the hanger.
Then we did a mock application of the leaf spring and noticed the exhaust tips would be in the way. The plan is to reroute the exhaust to where it comes out the side and not out the back.
post #93 of 1283 Old 04-12-2011, 12:00 PM Thread Starter
boarderofsnow
1979 CJ5
Here is where we hit the big snag. I ordered CJ rear hangers when I should have ordered XJ rear hangers. If any of you have dealt with XJ hangers you know that one eyelet is far larger than the other. Well since I wasn't planning to stretch it just yet (because of the need to move the gas tank elsewhere) I was just going to keep the XJ Leafs pointed the correct way. Well long story short the eyelet was to big for the hanger. I was burning shop time ($50 bucks a day) so we made the decision to go with the stretch. If any of you have done a stretch in the rear you know what must happen.
Fenders get trimmed and gas tank gets relocated.
So we hopped to it and started mounting the leafs while my buddy got to work on the fenders.
As you can see I used BTF shackles for the rear. They are beefy!
post #94 of 1283 Old 04-12-2011, 12:10 PM Thread Starter
boarderofsnow
1979 CJ5
So next was to Comp Cut the fenders. There is a real science to this. My suggestion woulkd be to tape it off first. We did 3in from the top of the tub to the bottom of the tap and started at the peak of the fenderwell.
post #95 of 1283 Old 04-12-2011, 12:21 PM Thread Starter
boarderofsnow
1979 CJ5
We finished the mounting of the leafs and slapped the tires back on and rolled her out. The XJ leafs are completely pancaked and I am worried with any additional weight the will S. So as I mentioned with the YJ's we will do an add-a-leaf in the rear. Here are the last pics I took as we rolled it out.
I still need to purchase a new gas tank. Extend the slip yoke on my rear drive line and fix my shifter cable.
post #96 of 1283 Old 04-15-2011, 03:15 PM Thread Starter
boarderofsnow
1979 CJ5
Just recieved the RCI Fuel Cell in the mail. I'm gaining 2 gallons and 5 inches of clearence. I just have to modify it to fit my set up and we may have to modify the crossmember inside the frame rail. More to come. The Tanks measurements are 30x17x7in's.
More to come.
post #97 of 1283 Old 04-15-2011, 05:32 PM
twinstickd20
1979 CJ7
My xj springs went flat too but im just going to deal with it for now and a flat spring will usually ride and flex better, nice 5 even tho im not a fan of the comp cut.
My Build Thread
twinstickd20 is offline
post #98 of 1283 Old 04-15-2011, 07:16 PM Thread Starter
boarderofsnow
1979 CJ5
Yeah I looked through your thread and yours and mine almost mirror each others. I still haven't figured out how to do the shock mounts front and rear yet and am kind of holding off since I will be going full width axles soon. I still have my tube fenders to put together in the front and need to place a guard around the rear comp cut to ensure I'm not cutting my tires. Great build!
post #99 of 1283 Old 04-15-2011, 07:26 PM
twinstickd20
1979 CJ7
My Build Thread
post #100 of 1283 Old 04-15-2011, 08:14 PM
bucklee00
1981 CJ5
great job documenting the build! i have my own cj5 (patches) project and hope to have a nice build thread, but it will be nothing like this!
bucklee00 is offline
post #101 of 1283 Old 04-16-2011, 08:15 PM Thread Starter
boarderofsnow
1979 CJ5
Thank you! Well we will be interested what comes out of your build. I have so many plans but continue to let my bank account think for me rather than my rig think for my bank account. lol Doing the measurements on the gas tank in the morning and should have it welded up and customized ready to drop in.
post #102 of 1283 Old 04-21-2011, 08:52 PM Thread Starter
boarderofsnow
1979 CJ5
Alright so we moved the gas tank up and it would not fit because of the crossmember. I figured this was going to happen but wasn't sure. So the next step was to get everything ready to accept the tank and to create a frame for the tank and skid plate.
Here is a pic of another Jeepers rig that gave me the idea for the frame.
post #103 of 1283 Old 04-21-2011, 09:23 PM Thread Starter
boarderofsnow
1979 CJ5
Now my axles sits quite a few inches back from where his sits so I took pictures and dropped them into piant. If this is something you haven't done before it can be a way to see how certain ideas you have may look on your rig.
Here is what I came up with. The red is the smaller frame 2in x 1in square tubing. The blue is the 2in x 2in square tubing. The 45 degree angle cuts on the blue will be for adapting the scrape plate to.
The first pic is what I have to remove (crossmember and body mounts) and the rest are my ideas for the fuel cell frame.
Also here is the picture for what modded gas tank will be once I take it to get welded. This is the only item I won't be doing myself because I am not at the point of welding alluminum yet. The 3 red lines on the top will get cut out and the red line around them will be the patch. The current filler neck will be cut off and over to the right a filler (Green arrow) and vent tube (red arrow) will be welded in. The last little red corners on the side will be the mounting brackets that will be welded in and sandwiched between the frame rail and the scrape plate.
Note - I have heard every idea in the book on how to do this blah blah blah almost to the point of frustration. So here is what I am doing going forward and appreciate any thoughts but I won't mount the tank in bed because I want the space back there. This idea I have should work well and have seen it incoporated on two other rigs and they have had no problems.
Enjoy.
post #104 of 1283 Old 04-21-2011, 09:36 PM Thread Starter
boarderofsnow
1979 CJ5
Also I didn't include it in the pic above but the fuel and return line will be on the other side of the tank. Fuel line will be in the bottom left corner and the return will be in the top right corner.
The idea with this is to get it to sit as flush as possible inside the frame rails. The original CJ5 tank was 13in tall. With this new tank sitting as flush as possible after the filler neck and lines have been removed it will only sit 8in below the bottom of the tub. Thats 5in of clearence and 2 extra gallons of gas. On top of that my back seat area will be fuel free! A lot of work but should be worth it.
post #105 of 1283 Old 04-21-2011, 09:51 PM Thread Starter
boarderofsnow
1979 CJ5
Next was the measurements and getting the old crossmember out. I know that the extended frame rail will stick down 2in from the bottom of the frame rail. The tank is about 7 1/2in so I will have a half in or so of play. So it was time to cut out the crossmember and get the weld areas sanded up for the new crossmember. Here are the pics. Oh yeah the screw driver you see is to hold the gas lines up and out of the way. Still thinking of how I will adapt them to the new tank. Any one know which line it the fuel and which is the return???
14 bolt , 5.3l vortec , atlas , cj5 , dana 60
Will`s 1979 CJ-5 Build BamaLonghorn Jeep CJ Forum 70 08-07-2011 02:35 PM
1979 CJ 5 Build up spcmac249 Jeep CJ Forum 20 07-03-2011 07:52 AM
1979 CJ5 Build TXST8tj Jeep CJ Forum 47 12-10-2009 11:25 AM
1979 CJ-7 build help RSfabrications Jeep CJ Forum 1 06-23-2009 09:30 AM
1979 CJ-5 gas tank sending unit filter Bigrey Jeep CJ Forum 1 11-10-2007 11:11 PM
