1979 CJ5 Build (Tank Killer) - Page 66 - JeepForum.com
 1Likes
post #976 of 1255 Old 04-18-2013, 10:13 PM Thread Starter
boarderofsnow
1979 CJ5
As promised here are the pics from the exhaust shop. still need to drop it and wrap it but my stuff from DEI hasn't come in yet. I also took pics of the clearance for the fuel pump, and the brake porportioning valve. I plan on redoing the brake lines soon but not soon enough so everything will have to stay where it is for now. I'm happy with it all for now. Plus it cost me $525 for the exhaust.
J.P.
President / Co-Founder
4 Wheel to Heal
"Real Heroes don't wear capes, They wear Dog Tags!"
CHECK OUT 4 WHEEL TO HEAL
4 Wheel to Heal
Build Thread
Facebook
boarderofsnow is offline
post #977 of 1255 Old 04-18-2013, 10:16 PM Thread Starter
boarderofsnow
1979 CJ5
Old vs New. Crazy to think this rig had a small block chevy in it just two months ago.....tons of @$$ pain in this motor swap....here is what I have to say....F...U...motorswap..lol
J.P.
4 Wheel to Heal
4 Wheel to Heal
Build Thread
Facebook
post #978 of 1255 Old 04-18-2013, 10:18 PM Thread Starter
boarderofsnow
1979 CJ5
Today I worked the winch controls. It was pretty straight forward on the wiring. Here is the pic of the winch control with the top off and the 12 volt guy wires tapped in. It will make for an easier way to winch in drastic situations. Also the To Do List is slowly growing smaller.
J.P.
4 Wheel to Heal
4 Wheel to Heal
Build Thread
Facebook
post #979 of 1255 Old 04-19-2013, 06:49 AM
Galt
Galt's Avatar
1983 CJ7
I think that rear exit dual looks kind of bad ***. Be careful wrapping that stuff, it will rust out a lot faster but I'm sure you are aware of that. Good luck with the finishing touches. Looks good so far.
A=A
1983 CJ7 304 V8
1985 CJ7 258 I6
1993 RX7 1.3L Rotary/ GT40R turbo/484 rwhp
2002 F-150 Lariat 5.4L V8
2007 GMC Yukon Denali 6.2L V8
Galt is offline
post #980 of 1255 Old 04-19-2013, 09:06 AM
ahar9
Looks f ucking sick man. I remember when I saw this thing on a trailer one day and fell in love lol
hold my beer
ahar9 is offline
post #981 of 1255 Old 04-19-2013, 09:35 AM
Dadamsnv
1977 CJ5
You can use a silicon spray over the wrap that helps with water and abrasion
I'm looking for a Scout II Dana 300. Drop me a line if you have any leads. Thanks
Dadamsnv is offline
post #982 of 1255 Old 04-19-2013, 10:04 AM
tonkatrucksryan
2014 JK Wrangler
Awesome build!!!
New build
26 Years USAF Retired 1MAY14
Past Jeeps:
04 TJ Rub,05 TJ, 75CJ5, 88YJ
tonkatrucksryan is offline
post #983 of 1255 Old 04-19-2013, 12:26 PM
83vert
1982 CJ7
Looks awesome, you should be proud of yourself
I am in deep
http://www.jeepforum.com/forum/f8/how-did-happen-rebuild-1113470/
83vert is offline
post #984 of 1255 Old 04-19-2013, 05:37 PM
Galt
Galt's Avatar
1983 CJ7
It will help some but it wont prevent. I sprayed that silicone on the wrapped manifold and down pipe from my turbo on my RX7 and that **** was covered in rust in one year.
A=A
1983 CJ7 304 V8
1985 CJ7 258 I6
Galt is offline
post #985 of 1255 Old 04-19-2013, 09:25 PM
Dadamsnv
1977 CJ5
:/ lame
Dadamsnv is offline
post #986 of 1255 Old 04-21-2013, 01:45 PM Thread Starter
boarderofsnow
1979 CJ5
Thanks Its growing on me. We will see how I feel the first time I hang it up on a rock.....or try and drop the fuel cell.....lol Yeah I am not exactly sure how much I will wrap.
Thanks brother. Tons of work and I still feel like I haven't scratched the surface yet.
Yeah I was planning on it. Wrap should be hear Tomorrow hopefully
Originally Posted by tonkatrucksryan View Post
Awesome build!!!
Thanks man appreciate it!
Thanks brother!
J.P.
4 Wheel to Heal
4 Wheel to Heal
Build Thread
Facebook
post #987 of 1255 Old 04-21-2013, 01:46 PM Thread Starter
boarderofsnow
1979 CJ5
Firday I had a chance to get back in the shop. The idea was to try and get as much done as possible. I did have a few issues I had already noticed with the rig. One area was steering. Somehow....not exactly sure.....the steering basically had moved a good amount. What I mean when I say this is I could only turn 1 quarter turn to the right and then had way too much travel to the left. So I had to drop the pitman arm then center the steering again to get everything as close to back in line as possible.
J.P.
4 Wheel to Heal
4 Wheel to Heal
Build Thread
Facebook
post #988 of 1255 Old 04-21-2013, 01:51 PM Thread Starter
boarderofsnow
1979 CJ5
Next was to upgrade the brakes. I had a buddy send me a booster custom built by a company in NC and everything bolted right in. So I drained the old master cylinder and then unbolted the two bolts. There is a cotter pin holding it onto the piston inside the firewall. Once thats removed, the arm slides off the piston and the master cylinder will pull out. The front and rear brake lines need to be removed the master cylinder....then its done. I then installed the new Master Cylinder and hooked everything back up. The only real difference in putting it all back together is the front brake line will go to the back and the back to the front. This is just how it fits for whatever reason. Next we bled the brakes and that was all she wrote. Power brakes to manual brakes is a huge difference. No more pushing the peddle to the floor....lol Last thing was hooking the vacuum line off the motor into the system.
J.P.
4 Wheel to Heal
4 Wheel to Heal
Build Thread
Facebook
post #989 of 1255 Old 04-21-2013, 01:52 PM Thread Starter
boarderofsnow
1979 CJ5
I had to do some slight modifications to the power steering reservoir to get it all to fit but its fine now. I have noticed a few times when the motor wants to hesitate or shut off. I never had that problem before with the vacuum line plugged up. Just seemed to start happening when I put the pwer brakes master cylinder in.
Last thing I did befor pulling out of the shop was the rollover valve on my fuel tank vent line. I tucked it all up under the drivers side tub.
J.P.
4 Wheel to Heal
4 Wheel to Heal
Build Thread
Facebook
post #990 of 1255 Old 04-21-2013, 04:03 PM
ahar9
I don't feel like reading all the way back to figure this out so how do you get the shop space to use? Is it a buddy's or do you pay a local place to use their shop or what? Jeeps looking good btw I can't wait to see the first trail run
hold my beer
ahar9 is offline
14 bolt , 5.3l vortec , atlas , cj5 , dana 60
Will`s 1979 CJ-5 Build BamaLonghorn Jeep CJ Forum 70 08-07-2011 03:35 PM
1979 CJ 5 Build up spcmac249 Jeep CJ Forum 20 07-03-2011 08:52 AM
1979 CJ5 Build TXST8tj Jeep CJ Forum 47 12-10-2009 12:25 PM
1979 CJ-7 build help RSfabrications Jeep CJ Forum 1 06-23-2009 10:30 AM
1979 CJ-5 gas tank sending unit filter Bigrey Jeep CJ Forum 1 11-11-2007 12:11 AM
