1979 CJ5 Build (Tank Killer) - Page 65 - JeepForum.com
 1Likes
post #961 of 1301 Old 04-14-2013, 06:40 PM Thread Starter
boarderofsnow
1979 CJ5
Originally Posted by doublins View Post
Well I feel your pain brother, and I'm hoping all's well. Was the motor a fresh rebuild w new cam or just a freshened up as-is motor?
No new internal parts. Was out of a wrecked Silverado with 66k miles on it.
Originally Posted by lucdog View Post
That sucks, sorry to here about it.
I was under the impression that FI systems used a oil pressure switch to keep 12 volts at the fuel pump, no pressure, pump shuts down.
Bill
Bill some do but most major car makers do not have this as a factory option. Just one of those things that I won't do again...lol Plent more motor swaps going forward. The LS conversion is just too easy and perfect for all applications.
J.P.
President / Co-Founder
4 Wheel to Heal
"Real Heroes don't wear capes, They wear Dog Tags!"
CHECK OUT 4 WHEEL TO HEAL
4 Wheel to Heal
Build Thread
Facebook
boarderofsnow is offline
post #962 of 1301 Old 04-14-2013, 07:56 PM Thread Starter
boarderofsnow
1979 CJ5
Finally rolled her out today with everything working. Muffler shop tomorrow.
http://youtu.be/18LP2pjFmw4
J.P.
4 Wheel to Heal
4 Wheel to Heal
Build Thread
Facebook
post #963 of 1301 Old 04-14-2013, 08:20 PM
WSS
WSS's Avatar
1972 CJ5
Awesome! Great news. Look forward to seeing her on the trail.
WSS
PS, you can do an oil sample before/during your first oil change to "see" whats going on. They work and will show trends if you use them often. About $20 a pop at the Cat dealer.
If you are a Purist, don't click here:
My CJ5 Build and fun stuff:
WSS is offline
post #964 of 1301 Old 04-14-2013, 10:03 PM
Dadamsnv
1977 CJ5
Sweet! For a well broken in motor, running out of oil hopefully won't be a deal breaker. She sure seems to run well
I'm looking for a Scout II Dana 300. Drop me a line if you have any leads. Thanks
Dadamsnv is offline
post #965 of 1301 Old 04-15-2013, 07:04 AM
doublins
Yeah, I'm really happy to hear that it was a worn-in motor- the damage would likely be far less than if he'd run a rebuild on no oil.
JP- glad to see it's back in action.
98 TJ Street Sleeper- 408ci Stroked Magnum V8
My Magnum V8 Build Thread:
doublins is offline
post #966 of 1301 Old 04-15-2013, 03:00 PM Thread Starter
boarderofsnow
1979 CJ5
You and me both....dropped that motha off at the exhaust shop today! Now time for
J.P.
4 Wheel to Heal
4 Wheel to Heal
Build Thread
Facebook
post #967 of 1301 Old 04-15-2013, 07:20 PM
Dadamsnv
1977 CJ5
You earned it!
Dadamsnv is offline
post #968 of 1301 Old 04-15-2013, 07:22 PM
WSS
WSS's Avatar
1972 CJ5
Cheers!
All will be well.
WSS is offline
post #969 of 1301 Old 04-16-2013, 07:13 AM
RDH
What exhaust are you going with?
1978 CJ7: 304, 3Spd, AMC 20 Rear, Thrush Welded Mufflers W/ Turndowns, Unknown Front, Worn out Dana 20 case
RDH is offline
post #970 of 1301 Old 04-16-2013, 08:56 AM Thread Starter
boarderofsnow
1979 CJ5
The plan was to go single exhaust. Have the passenger side manifold drop down and wrap around the front of the oil pan. It would then Y into the drivers side and run back to a muffler and then exit out the side. I am reusing my flowmaster muffler and asked to have a flange added after the Y so when the exhaust shop is done I can drop it and wrap it. The less heat coming off it the better.
J.P.
4 Wheel to Heal
4 Wheel to Heal
Build Thread
Facebook
post #971 of 1301 Old 04-16-2013, 09:53 AM
Dadamsnv
1977 CJ5
Exhaust wrap will make it run a bit hotter temp wise. The wrap, as used for power increases, is designed to raise the output temp of the combustion process by insulating heat loss from your headers and lower the intake temperature by shielding heat from the intake. Thermodynamically speaking, the greater the difference between input temp an output temp of such a system the greater the system efficiency the greater the performance. But it's at the cost of higher running temps.
Sorry for the earful
Dadamsnv is offline
post #972 of 1301 Old 04-16-2013, 11:17 PM
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
Physics 190 - Mechanics and Heat. This man speaks the truth!
Andy, KD8EIA
Originally Posted by Jetscuh
Grewe02 is offline
post #973 of 1301 Old 04-16-2013, 11:24 PM
Dadamsnv
1977 CJ5
Dadamsnv is offline
post #974 of 1301 Old 04-17-2013, 09:46 AM Thread Starter
boarderofsnow
1979 CJ5
Heat I can deal with, with this motor. It runs more efficiently and cooler than any other motor I have seen. Plus I'm running dual fans and a four core radiator. Got her back from the exhaust shop yesterday and man am I Happy, Happy, Happy. Not a HUGE fan of the exit strategy but I did give the guy the green light to do what he wanted in certain areas and did not have a good game plan for the exit. We will see what happens on the rocks. But man the thing runs great, seems to be no issues I have seen yet. Still needs some serious work before wheeling next weekend. Keeping my fingers crossed it all comes together in time.
http://www.youtube.com/watch?v=3-ext...ature=youtu.be
J.P.
4 Wheel to Heal
4 Wheel to Heal
Build Thread
Facebook
post #975 of 1301 Old 04-17-2013, 10:49 AM
Dadamsnv
1977 CJ5
Dadamsnv is offline
14 bolt , 5.3l vortec , atlas , cj5 , dana 60
Will`s 1979 CJ-5 Build BamaLonghorn Jeep CJ Forum 70 08-07-2011 03:35 PM
1979 CJ 5 Build up spcmac249 Jeep CJ Forum 20 07-03-2011 08:52 AM
1979 CJ5 Build TXST8tj Jeep CJ Forum 47 12-10-2009 12:25 PM
1979 CJ-7 build help RSfabrications Jeep CJ Forum 1 06-23-2009 10:30 AM
1979 CJ-5 gas tank sending unit filter Bigrey Jeep CJ Forum 1 11-11-2007 12:11 AM
