1979 CJ5 Build (Tank Killer) - Page 53 - JeepForum.com
 1Likes
post #781 of 1255 Old 03-02-2013, 03:33 PM Thread Starter
boarderofsnow
1979 CJ5
Day 3 was oh so much fun! I started with the transfer case. My tranny seal and T-Case seals were bad and I was getting fluid back and forth between the two. So I started at the Trans To Transfer Case Adapter. This is 8 bolts and the Adapter slides off the T-Case. Also the shifting handle comes with it after a cotter pin is removed. From there I pulled the retaining ring on the bearing and it all slipped out of the adapter housing. There is two seals inside the adapter assembly. One for the trans and the other for the T-Case. They can be removed easily with a punch/hammer from the other side. Next was dropping the new seals in and putting the assembly back together.
J.P.
President / Co-Founder
4 Wheel to Heal
"Real Heroes don't wear capes, They wear Dog Tags!"
CHECK OUT 4 WHEEL TO HEAL
4 Wheel to Heal
Build Thread
Facebook
boarderofsnow is offline
post #782 of 1255 Old 03-02-2013, 03:36 PM Thread Starter
boarderofsnow
1979 CJ5
Next I pulled the PTO cover and had a peak inside. Simple 6 bolts. Gears all looked good. Fresh gasket and sealed it up.
J.P.
4 Wheel to Heal
4 Wheel to Heal
Build Thread
Facebook
post #783 of 1255 Old 03-02-2013, 03:43 PM Thread Starter
boarderofsnow
1979 CJ5
The next part hit me by surprise. I did a rushed amount of research in pulling the T-Case apart as I was running out the door. I pulled the Front Output Shaft Bearing Retainer and did noit realize the Rear Bearing was filled with about 30 pins that all fell out once I pulled the cap off. Some fell on the floor other fell inside the T-Case.......Yeah awesome fun times all rolled into OMG what the HELL just happened...lol. So with a magnet I routed around inside the T-Case till I found them all. Then covered them with grease and with a new gasket slid the cover back on. This definately slowed me down. Also the cap had a side broke off so I filled that hole and bolt with RTV.
J.P.
4 Wheel to Heal
4 Wheel to Heal
Build Thread
Facebook
post #784 of 1255 Old 03-02-2013, 03:46 PM Thread Starter
boarderofsnow
1979 CJ5
Next I cleaned up the transmission and did a tiny bit of maintenance to it. I did clip off the Kickdown cable as it had been burned through previously.
J.P.
4 Wheel to Heal
4 Wheel to Heal
Build Thread
Facebook
post #785 of 1255 Old 03-02-2013, 03:52 PM Thread Starter
boarderofsnow
1979 CJ5
Then it was time for the firewall. This was half assed on my part because of the bay I was in. I was spraying dust and metal all over the car parked next to me. We then rolled the rig outside and I threw a coat of primer on it. This will have to do until I get the motor in and mounted. There is a list of a ton of stuff to do but I'll get there. Also painted the frame rails.
J.P.
4 Wheel to Heal
4 Wheel to Heal
Build Thread
Facebook
post #786 of 1255 Old 03-02-2013, 03:56 PM Thread Starter
boarderofsnow
1979 CJ5
I was going to try and get the motor mounted to the tranny today but ran out of time. I did pull out my Autometer accessories and popped them in. The back oil temperature will take the place of the oil pressure sending unit. Its an fitting from Autometer that you just drop right in in its place. We were being rushed out so I didn't get to finish snapping pics. The other is the Water Temperature which goes in the back hole of the passenger side head. There is a plug there and you remove it.
J.P.
4 Wheel to Heal
4 Wheel to Heal
Build Thread
Facebook
post #787 of 1255 Old 03-02-2013, 03:58 PM Thread Starter
boarderofsnow
1979 CJ5
I'm exhausted! Still more work needs to be done! lol. Now to buy some parts.
J.P.
4 Wheel to Heal
4 Wheel to Heal
Build Thread
Facebook
post #788 of 1255 Old 03-02-2013, 04:17 PM
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
What kind of water temp sensor are you using? Electronic I assume? I want to drill out that hole and tap it for a larger mechanical gauge.
Andy, KD8EIA
Originally Posted by Jetscuh
Grewe02 is offline
post #789 of 1255 Old 03-02-2013, 04:28 PM Thread Starter
boarderofsnow
1979 CJ5
Autometer electronic
J.P.
4 Wheel to Heal
4 Wheel to Heal
Build Thread
Facebook
post #790 of 1255 Old 03-02-2013, 04:42 PM
WSS
WSS's Avatar
1972 CJ5
Moving along pretty good. Those "little" slow downs suck. Glad you did what you could to the firewall while it was easy to get too. I have done a some projects that I skipped a few details to pick up time and wish I had not later.
WSS
WSS is offline
post #791 of 1255 Old 03-03-2013, 08:30 PM Thread Starter
boarderofsnow
1979 CJ5
Day 4 motor swap. I started with the power steering pump. I had to remove the old brackets from the Small Block Conversion and the bracket off the back of the LS Pump. The pump mounted right up no problem I am thinking I can mount the reservoir on the side of the engine above the pump.
J.P.
4 Wheel to Heal
4 Wheel to Heal
Build Thread
Facebook
post #792 of 1255 Old 03-03-2013, 08:38 PM Thread Starter
boarderofsnow
1979 CJ5
Next was bushings...lol. Here are the new AA bushings. Also there was some much needed TLC for the Jeeps body bushings. They had seen better days...ha ha ha
J.P.
4 Wheel to Heal
4 Wheel to Heal
Build Thread
Facebook
post #793 of 1255 Old 03-03-2013, 08:47 PM Thread Starter
boarderofsnow
1979 CJ5
I wanted to make sure the tranny looked good inside so I pulled the Trans cover and swapped out the filter. Overything internally looked good. So I sealed it back up. I will have to open it again to weld in the trans temperature bung from Autometer. I'll plobably add a drain plug as well while I'm at it.
J.P.
4 Wheel to Heal
4 Wheel to Heal
Build Thread
Facebook
post #794 of 1255 Old 03-03-2013, 09:26 PM Thread Starter
boarderofsnow
1979 CJ5
The next area went really quick because I had trouble with the crappy pully install kit the shop had and getting the power steering pump pully took way longer than I expected. So unfortunately with no help I had to get the motor mounted to the tranny and dropped in and I was running out of time. So I didn't have a chance to take any pictures of mating the trans to the motor. It was straight forward with the spacer I had purchased. Everything went together with no problems. Nathan showed up and was doing some work on his axle shaft and helped get the motor lowered in and bolted up. The universal mounting brackets which are pretty thick didn't help with the old moutning location. The bushing were pretty tight to get them to fit into the holes. They will most likely wear pretty quickly.
J.P.
4 Wheel to Heal
4 Wheel to Heal
Build Thread
Facebook
post #795 of 1255 Old 03-03-2013, 09:30 PM Thread Starter
boarderofsnow
1979 CJ5
So without further ado.....The Tank Killer has an LS!
J.P.
4 Wheel to Heal
4 Wheel to Heal
Build Thread
Facebook
14 bolt , 5.3l vortec , atlas , cj5 , dana 60
Will`s 1979 CJ-5 Build BamaLonghorn Jeep CJ Forum 70 08-07-2011 02:35 PM
1979 CJ 5 Build up spcmac249 Jeep CJ Forum 20 07-03-2011 07:52 AM
1979 CJ5 Build TXST8tj Jeep CJ Forum 47 12-10-2009 11:25 AM
1979 CJ-7 build help RSfabrications Jeep CJ Forum 1 06-23-2009 09:30 AM
1979 CJ-5 gas tank sending unit filter Bigrey Jeep CJ Forum 1 11-10-2007 11:11 PM
