1979 CJ5 Build (Tank Killer) - Page 52 - JeepForum.com
 1Likes
post #766 of 1255 Old 02-28-2013, 11:45 PM
8pitcher
8pitcher's Avatar
Originally Posted by Dadamsnv
Nice man! Big day!
X2 very big day.
Ill take the sbc for 10$
8pitcher is offline
post #767 of 1255 Old 03-01-2013, 09:19 PM Thread Starter
boarderofsnow
1979 CJ5
Originally Posted by Dadamsnv View Post
Nice man! Big day!
Thanks! Its been fun!
Originally Posted by 8pitcher View Post
X2 very big day.
$600 its yours!
J.P.
President / Co-Founder
4 Wheel to Heal
"Real Heroes don't wear capes, They wear Dog Tags!"
CHECK OUT 4 WHEEL TO HEAL
4 Wheel to Heal
Build Thread
Facebook
boarderofsnow is offline
post #768 of 1255 Old 03-01-2013, 09:38 PM Thread Starter
boarderofsnow
1979 CJ5
Day two motor sawp and feels like I made some real progress today. Today Daniel Stiener (Commander Dan on here) stepped in to help. There is no way I could have gotten nearly as much done without him! So THANKS MAN! So when I left yesterday all that was left to pull was the top two bolts connecting the trans to the T-Case. So we started there, pulled those, choked the fuel line, and boom motor pullin time! Once we got it back ground level I pulled the motor mounts. About time I make an appearance in my own thread....lol
J.P.
4 Wheel to Heal
4 Wheel to Heal
Build Thread
Facebook
post #769 of 1255 Old 03-01-2013, 09:47 PM Thread Starter
boarderofsnow
1979 CJ5
Next was dropping the trans and T-Case. I went ahead and drained the T-Case and we set a rod accross the frame and some bolts throught the Tranny for support. Then we moneky F'd two jacks, a few different blocks of wood and some extension mounts for the lift and attempted to lower the tanny / T-Case. I also threw a strap just incase....lol. We got it down to where the jacks were level and bottomed out and then were trying remove the wood when it shifted and found its way to the floor. Luckily nothing broke and no idiots were harmed..lol.
J.P.
4 Wheel to Heal
4 Wheel to Heal
Build Thread
Facebook
post #770 of 1255 Old 03-01-2013, 09:55 PM Thread Starter
boarderofsnow
1979 CJ5
We then seperated the trans from the T-Case. The seal between the two is bad and I wanted to fix it while it was down and do some other maintenance as well. I had originally bought a seal kit so I'll start replacing those while its down. Never opened one up before so it should be a good learning curve.
J.P.
4 Wheel to Heal
4 Wheel to Heal
Build Thread
Facebook
post #771 of 1255 Old 03-01-2013, 10:05 PM Thread Starter
boarderofsnow
1979 CJ5
I then did a little work on the LS motor. For the motor to mount up to a Turbo 350 Trans you need a spacer to place on the flex plate. There is a ton of information out there that is all about linking them together. Anything from use a 6.0 flex plate to having to drill holes out of the spacer. I must have lucked out because the spacer I bought from Jegs P/N 809-12563532 worked just fine. Bolted right up. Next was the motor mounts which I'll be honest I was nervous about if the C6 Corvette manifolds would clear them or not. My motor mounts are Advanced Adapters and there is not a ton of info out there considering. Also keep in mind this is a small block conversion first and now the LS conversion over the top of it. The drivers side cleared fine but the passenger side was in the way so I had to take the heat shield off and do some cutting.
J.P.
4 Wheel to Heal
4 Wheel to Heal
Build Thread
Facebook
post #772 of 1255 Old 03-01-2013, 10:17 PM Thread Starter
boarderofsnow
1979 CJ5
Now let us address the Trans cross member. This is the original pic of what I purchased in the build in 2009 from the shop that dropped in my SBC and I paid them 4.5k for all their hardwork....idiots. So check this out, crossmember out, next pic is the massive hole I found on the top half of it. Now this really is just piss pour work. They obviously cut the piece too long and rather than just fix it the tried to cover the massive hole with weld. So I had to cut it open, put in a plate, and then weld in a patch. Not happy about that little surprise. Look I have a ton of friends who own shops and do great work for people so please know I support the jeeping world and local businesses that do it right. This is just one of those cases where they chose not just go the extra mile and it was on my dime. Rant over.....
J.P.
4 Wheel to Heal
4 Wheel to Heal
Build Thread
Facebook
post #773 of 1255 Old 03-01-2013, 10:35 PM Thread Starter
boarderofsnow
1979 CJ5
I closed out the night by taking a wire wheel to the inside of the frame rails. They were still caked in mud, even after my hour long power wash, after the dumb decision to hit the mud hole at big dogs in September. It took a while to get them cleaned up but underneath there were no signs of pitting or rust, which at this time for me is a good thing. There was a ton of dirt around the bolts holding the crossmember in and I wish I had time to get it to a pressure washer and get the inside of the frame sprayed out. I also removed the bracket for the parking brake and the old rear bracket I had outline in a picture on the last page. I then removed the old fuel lines on the drivers side. All thats left now is the brake lines and the fuel line on the passenger side which I'll remove once I drop the gas tank. These are a couple of pics to just show the space available for Fuel pump, filter and the exhaust.
J.P.
4 Wheel to Heal
4 Wheel to Heal
Build Thread
Facebook
post #774 of 1255 Old 03-01-2013, 10:36 PM Thread Starter
boarderofsnow
1979 CJ5
Another day down and I feel there is real progress to show. I need to start making a list of the stuff I need as I am going or I'm bound to forget something...lol
J.P.
4 Wheel to Heal
4 Wheel to Heal
Build Thread
Facebook
post #775 of 1255 Old 03-01-2013, 11:31 PM
8pitcher
8pitcher's Avatar
$600 its yours!
Nah 10 sounds better haha I'm broke I gotta get tires for my Jk.
8pitcher is offline
post #776 of 1255 Old 03-02-2013, 01:25 AM
Dadamsnv
1977 CJ5
Goodness gracious man! Do your back and knees ache yet??
I'm looking for a Scout II Dana 300. Drop me a line if you have any leads. Thanks
Dadamsnv is offline
post #777 of 1255 Old 03-02-2013, 06:59 AM Thread Starter
boarderofsnow
1979 CJ5
Yeah life must be real hard owning 2 Jeeps!
Not yet but I'm getting there. Advil every night before bed helps...lol
J.P.
4 Wheel to Heal
4 Wheel to Heal
Build Thread
Facebook
post #778 of 1255 Old 03-02-2013, 08:08 AM
8pitcher
8pitcher's Avatar
Yeah very haha. Oh and may start a new one this summer oh plus I have a truck
8pitcher is offline
post #779 of 1255 Old 03-02-2013, 09:10 AM
CmmdrDan
Ohh snap. I havent been on here in a long while. It was.great helping ya out yesterday man. Sorry i couldnt help more
CmmdrDan is offline
post #780 of 1255 Old 03-02-2013, 03:23 PM Thread Starter
boarderofsnow
1979 CJ5
lol Must be nice
Dude you were a tremendous help and I actually have a 6 pack of beer here at the house for you.
J.P.
4 Wheel to Heal
4 Wheel to Heal
Build Thread
Facebook
14 bolt , 5.3l vortec , atlas , cj5 , dana 60
Will`s 1979 CJ-5 Build BamaLonghorn Jeep CJ Forum 70 08-07-2011 02:35 PM
1979 CJ 5 Build up spcmac249 Jeep CJ Forum 20 07-03-2011 07:52 AM
1979 CJ5 Build TXST8tj Jeep CJ Forum 47 12-10-2009 11:25 AM
1979 CJ-7 build help RSfabrications Jeep CJ Forum 1 06-23-2009 09:30 AM
1979 CJ-5 gas tank sending unit filter Bigrey Jeep CJ Forum 1 11-10-2007 11:11 PM
