1979 CJ5 Build (Tank Killer) - Page 51 - JeepForum.com
 1Likes
post #751 of 1255 Old 02-14-2013, 09:15 PM
WSS
WSS's Avatar
1972 CJ5
Thats the confusion, sorry! You will be there but w/o the rig and new set-up. I thought that would be a push, but hey, I have seen some stuff done in record time before LOL.
WSS
WSS is online now
post #752 of 1255 Old 02-24-2013, 06:21 PM Thread Starter
boarderofsnow
1979 CJ5
WSS
Its all good! Maybe getting the swap started on Thursday..... We will see!
J.P.
President / Co-Founder
4 Wheel to Heal
"Real Heroes don't wear capes, They wear Dog Tags!"
CHECK OUT 4 WHEEL TO HEAL
4 Wheel to Heal
Build Thread
Facebook
boarderofsnow is offline
post #753 of 1255 Old 02-24-2013, 06:26 PM Thread Starter
boarderofsnow
1979 CJ5
So last weekend we went to Motorama and had a booth as 4 Wheelto Heal. Had a great weekend and met plenty of awesome people. Maybe some new partnerships in the future as well. We had a few Warriors also stop in and we took them around and spent most of the day with them. Had some new friends and supporters of 4W2H stop in. Great meeting Clint Wilson and Jeremy Hopper! All in all great show and event!
858984_475002642547495_80146249_o.jpg   830481_475209909193435_1640679197_o.jpg   860635_475322285848864_2066502934_o.jpg   223544_476576399056786_1467726008_n.jpg
J.P.
4 Wheel to Heal
4 Wheel to Heal
Build Thread
Facebook
post #754 of 1255 Old 02-24-2013, 06:28 PM Thread Starter
boarderofsnow
1979 CJ5
Oh just noticed this thread passed the 60k mark in views! That is so crazy! Hopefully all you Jeepers get something out of this thread! I really appreciate all the support and great comments! I love Jeeps, and love the Off-Road Community!
J.P.
4 Wheel to Heal
4 Wheel to Heal
Build Thread
Facebook
post #755 of 1255 Old 02-24-2013, 06:34 PM Thread Starter
boarderofsnow
1979 CJ5
So I did manage to make it to the shop today for about two hours before they closed and wanted to knock out the rear main seal while the motor was still out of the vehicle. This was something I and my buddy, who is doing the same swap into his YJ, thought would be a better safe than sorry type of thought process. Also I needed to remove the Flex Plate anyway for when I add my spacer for the turbo 350 tranny mating. So first I started by removing the Flex Plate. Its just a simple 6 bolts and I used a punch to keep the Flex Plate from turning
J.P.
4 Wheel to Heal
4 Wheel to Heal
Build Thread
Facebook
post #756 of 1255 Old 02-24-2013, 07:06 PM Thread Starter
boarderofsnow
1979 CJ5
For the rear main seal I removed the 14 bolts that hold it to the motor, including the 2 bottom oil pan bolts. From there the I removed and replaced the Crank Seal. It wasn't hard to get off but prying wasn't getting it done so I used a punch from the other side to bend it to my will...lol. Also it comes with a plastic piece that sits inside the crank seal when you purchase a new one...$24.00 Make sure you utilize the plastic piece when mounting the seal back over the Crank to ensure the seal isn't torn or reversed in the process. There is the new seal and I also took a look at the insde of the rear main area to make sure everything looked good. I am still farely confident this motor will run strong for many years to come considering what I have seen of the open areas I have accessed. A clean motor is a healthy motor???
J.P.
4 Wheel to Heal
4 Wheel to Heal
Build Thread
Facebook
post #757 of 1255 Old 02-24-2013, 07:09 PM Thread Starter
boarderofsnow
1979 CJ5
That was all I had a chance to do before the shop closed up for the day. This week as mentioned above I may make the decision on my time off Thurs-Sunday to pull my SBC. I am also mailing out my wiring harness tomorrow to Wayne Hartwig to get cleaned up and tuned! $400 isn't a bad price for what they will do to the harness! More to come plus parts ordering tomorrow! Back to the build process and studying this swap!
J.P.
4 Wheel to Heal
4 Wheel to Heal
Build Thread
Facebook
post #758 of 1255 Old 02-24-2013, 09:20 PM
Dadamsnv
1977 CJ5
The beast looks great at the booth man!
I'm looking for a Scout II Dana 300. Drop me a line if you have any leads. Thanks
Dadamsnv is online now
post #759 of 1255 Old 02-26-2013, 06:34 PM
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
J.P., I remember you asking me about a fuel pump. Did you get one yet? Here is what I'm researching right now... Apparently they supply the required 58 PSI plus some. Pair that with a vette regulator and jackpot. Lots of stuff on Pirate that I have to read still. Just thought you'd like to know.
http://www.partsgeek.com/gbproducts/...Fap_Qgod9zoAng
Andy, KD8EIA
Originally Posted by Jetscuh
Grewe02 is offline
post #760 of 1255 Old 02-26-2013, 09:32 PM Thread Starter
boarderofsnow
1979 CJ5
Thanks man! Last time it will be spotted at an event with a small block chevy!
Thanks for the post man. Unfortunately I will not be going in tank for my set up. As far as the corvette regulator thats if you are not running a return line from the motor. At this time I will be. Sometime in the future I may look into a returnless system and incoporate the corvette regulator back to the tank. Thanks for the info but it won't apply to my build.
J.P.
4 Wheel to Heal
4 Wheel to Heal
Build Thread
Facebook
post #761 of 1255 Old 02-27-2013, 04:50 PM Thread Starter
boarderofsnow
1979 CJ5
Brown Santa stopped by the house with a box from Jegs.
I ordered
20ft of Aeroquip Starlite fuel line (P/N 023-FCU0620) - $121.99
Russell Fuel Rail Fitting 3/8, -6an (P/N 799-644120) - $14.99
Russell Fuel Rail Fitting 5/16, -6an (P/N 799-644110) - $14.99
GM Speedo Housing (P/N 890-880021) - $12.99
LS C/Shaft-F/Plate Spacer (P/N 809-12563532) - $36.99
The spacer is needed to adapt the turbo 350 Trans to the motor. The GM Speedo housing hopefully fixes the leak I continue to get out of the speedo cable housing on the trans.
I went with the russell fittings to help keep the fuel lines from popping off like the plastic internal clips have been known to do when not installed properly. You can never be too safe with fuel being sent at 55psi
J.P.
4 Wheel to Heal
4 Wheel to Heal
Build Thread
Facebook
post #762 of 1255 Old 02-28-2013, 09:35 PM Thread Starter
boarderofsnow
1979 CJ5
WOW what a long day! With 5 hours of sleep after working last night I powered through getting everything ready and by 1pm I had the Jeep on the trailer at the shop. I was hoping I'd have a few hands around but everyone I reached out to said they were busy. So I started pulling the fenders, then the front clip (grill). Drained the radiator and disco'd the tranny cooler. By 4pm I had the front clip off and the SBC was exposed.
J.P.
4 Wheel to Heal
4 Wheel to Heal
Build Thread
Facebook
post #763 of 1255 Old 02-28-2013, 09:52 PM Thread Starter
boarderofsnow
1979 CJ5
Drivelines were removed. Next was getting the exhaust removed. Everything went pretty smoothly. Since this motor had been installed in the last 5 years all of the hardware came out pretty easy. After I dropped the exhaust I emptied all of the fluid from the motor, trans, and power steering. I also took some pics of the room I will have with the exhaust removed. Looks like I won't have too many problems clocking the Atlas once its in. There is a bracket on the drivers side that is original that I will cut out to as seen in the pic to help make the drivers side better for the exhaust routing.
J.P.
4 Wheel to Heal
4 Wheel to Heal
Build Thread
Facebook
post #764 of 1255 Old 02-28-2013, 10:08 PM Thread Starter
boarderofsnow
1979 CJ5
I worked on the motor and removing the power steering PSC pump. A ton of wiring was gone through and sorting out the mess I had created with all the non-sense I had going on. I pulled the headers so it didn't tear anything up when I go to pull the motor. That was the last of it for the day. When I got home I had a few packages sitting at home waiting for me. One was some tools I picked up for the swap and my exhaust flanges from yoshifab. We will see if they match up tomorrow.
http://www.yoshifab.com/store/index....0&review=write
J.P.
4 Wheel to Heal
4 Wheel to Heal
Build Thread
Facebook
post #765 of 1255 Old 02-28-2013, 11:44 PM
Dadamsnv
1977 CJ5
Nice man! Big day!
14 bolt , 5.3l vortec , atlas , cj5 , dana 60
Will`s 1979 CJ-5 Build BamaLonghorn Jeep CJ Forum 70 08-07-2011 02:35 PM
1979 CJ 5 Build up spcmac249 Jeep CJ Forum 20 07-03-2011 07:52 AM
1979 CJ5 Build TXST8tj Jeep CJ Forum 47 12-10-2009 11:25 AM
1979 CJ-7 build help RSfabrications Jeep CJ Forum 1 06-23-2009 09:30 AM
1979 CJ-5 gas tank sending unit filter Bigrey Jeep CJ Forum 1 11-10-2007 11:11 PM
