1979 CJ5 Build (Tank Killer) - Page 12 - JeepForum.com
 1Likes
post #166 of 1287 Old 05-23-2011, 06:38 AM
huntersdad
huntersdad's Avatar
1985 CJ8
Looks great!
S/f,
Tim Hamilton
/l ,[____],
l---L -OlllllllO-
()_)-()_)-o-)_)
huntersdad is offline
post #167 of 1287 Old 05-23-2011, 02:33 PM Thread Starter
boarderofsnow
1979 CJ5
So I broke down finally. I went ahead and purchased everything I will need for this current build. The only thing that will be left for this is rims and drive shafts. I hope I have considered every angle possible to meet the time line we are working with to be ready by June.
Here is what I got.
Black Bird - Bracket Dana 60 Front
http://www.blackbirdscustomtrucks.com/index25.html
I went with Shawn Miller and his brake kits for the rear and rotors and calipers for the front.
http://www.pirate4x4.com/forum/showthread.php?t=746609
Blue Torch Fab
BTF Track Bar Links
http://www.bluetorchfab.com/Product/...e-14-Bolt.aspx
BTF Leaf Spring Shackle Plates
http://www.bluetorchfab.com/Product/...le-Plates.aspx
BTF Poly Bushing
http://www.bluetorchfab.com/Product/...y-Bushing.aspx
BTF 14 Bolt Pinion Guard
http://www.bluetorchfab.com/Product/...ion-Guard.aspx
OFFroad Design -
U Bolt Kit Dana 60
U Bolts Corp 14
High Steer Kit
http://www.offroaddesign.com/catalog...0crossover.htm
Spicer greasable D60 u-joint
Steering Stabilizer Bracket
Brake Proportioning Valve
Proportioning Valve
Combination Valve Disc/Disc
Part# PV-4
Great replacement for 4 wheel Disc
http://www.the-jeep-guy.com/brakes.htm
Hope this is more than what I will need for this axle swap. If any of you read through this and have suggestion I may not have thought of please feel free to post them........I feel broke....
boarderofsnow is offline
post #168 of 1287 Old 05-23-2011, 06:07 PM
SonicR1
Just got caught up… love it!!! I want to go full width!!! But I want to be able to drive on the street…
Keep up the good work!!!
... I guess I'm gonna have to fix that too…….
2005 Wrangler X 4.0/6 speed, Dana 30/Ford 8.8--4.88--Eaton E-Lockers, 35" MT/R, Smittybilt bumpers/rockers/winch, SonicFab tire carrier, RE 3.5 springs, Zone 1.25 BL, FullTraction 3 link upper rear, RE super flex lower rears, UCF ultra high skid and lo/pro mount, brown dog mml.
SonicR1 is offline
post #169 of 1287 Old 05-24-2011, 11:38 AM Thread Starter
boarderofsnow
1979 CJ5
Originally Posted by huntersdad View Post
Looks great!
Thanks! Hopefully my bearing and seals kits come in today so I can get started on the rebuilds of both axles tomorrow.
post #170 of 1287 Old 05-24-2011, 11:39 AM Thread Starter
boarderofsnow
1979 CJ5
Thanks I really appreciate it. Well I won't be afraid to drive it on the roads around town but will trailer it most places. It has historic tags so most cops won't mess with me. Fingers crossed......
post #171 of 1287 Old 05-24-2011, 03:30 PM Thread Starter
boarderofsnow
1979 CJ5
I just got the bearing and seal kits in today. I also have finished cleaning up the 14 Bolt and its in the paint stage.
post #172 of 1287 Old 05-25-2011, 08:02 PM Thread Starter
boarderofsnow
1979 CJ5
Alright so I got a little farther on the axles today. Drug them back to the shop after some krylon paint job work. We started with the pinions and removing the bearings. This was done with a press. Here are the two pinions together after they had the bearings pressed off.
post #173 of 1287 Old 05-25-2011, 08:03 PM Thread Starter
boarderofsnow
1979 CJ5
Next we removed the bearings from the carriers. Then since the 14bolt carrier didn't require shims we pressed the new bearings back on.
post #174 of 1287 Old 05-25-2011, 08:05 PM Thread Starter
boarderofsnow
1979 CJ5
We then got both of the bearings back onto the pinions and I took a quick trip home to see if UPS has come in my absense and.....BAM New Diff covers arrived.
post #175 of 1287 Old 05-25-2011, 08:08 PM Thread Starter
boarderofsnow
1979 CJ5
I also recieved my 1350 Yokes for the 14Bolt and the T-Case and this ment I could set me preload of my 14bolt. Here is the old compared to the new. This will allow me to go to UBolts instead of straps.
post #176 of 1287 Old 05-26-2011, 11:06 PM Thread Starter
boarderofsnow
1979 CJ5
So another long day in the shop. Before I headed to the shop though the mail man met me at the door. Here is what he brought.
Two front Dana 60 Caliper brackets from Blackbirds Custom Trucks.
Front and rear rotors from Shawn Miller.
2 sets of calipers from Shawn Miller.
The rear caliper brackets from Shawn Miller.
14 Bolt Pinion protection from Blue Torch Fab.
post #177 of 1287 Old 05-26-2011, 11:56 PM
Coiz
1979 CJ7
As my old boss would always say "you can't hide money".
Stout drivetrain for sure.
Mike
Coiz is offline
post #178 of 1287 Old 05-27-2011, 08:50 AM Thread Starter
boarderofsnow
1979 CJ5
Yeah this conversion hasn't been cheap! That is a fact! I will say though for the price that it would have cost me to buy both of these axles fully built from someone rather than doing it myself I sure saved a lot more money. When I get online and see Dana 60's fully built for up to 6k I know I'm saving money.
It sure is a lot of work though. My girlfriend has all but had enough by this point.
So I bought her a BTF tank top to help with the process.
post #179 of 1287 Old 05-27-2011, 08:53 AM Thread Starter
boarderofsnow
1979 CJ5
Got to the shop and started working on getting the preload set for the Dana 60 pinion. After trial and error. We were able to get the preload within about 20in lbs. Then with that and the Corp 14 preload set I moved onto switching lugs out from the disc brakes. Not fun!
post #180 of 1287 Old 05-27-2011, 08:55 AM Thread Starter
boarderofsnow
1979 CJ5
Finished getting all of the brakes done finally.
14 bolt , 5.3l vortec , atlas , cj5 , dana 60
Will`s 1979 CJ-5 Build BamaLonghorn Jeep CJ Forum 70 08-07-2011 02:35 PM
1979 CJ 5 Build up spcmac249 Jeep CJ Forum 20 07-03-2011 07:52 AM
1979 CJ5 Build TXST8tj Jeep CJ Forum 47 12-10-2009 11:25 AM
1979 CJ-7 build help RSfabrications Jeep CJ Forum 1 06-23-2009 09:30 AM
1979 CJ-5 gas tank sending unit filter Bigrey Jeep CJ Forum 1 11-10-2007 11:11 PM
