1979 CJ5 Build (Tank Killer) - Page 10 - JeepForum.com
 1Likes
post #136 of 1255 Old 05-13-2011, 01:33 PM
Deadman 94 xj
1977 CJ5
Cool build and cool thread!
Question for ya, is that "renagade" kit you put on a decal or a paint on stencil type deal?
I'm actually looking for a stencil for mine to be able to paint on.
Edit: I see you just traced your old decals. That turned out really good.
77 CJ5. 304, t-150, D20
Deadman 94 xj is offline
post #137 of 1255 Old 05-13-2011, 04:45 PM Thread Starter
boarderofsnow
1979 CJ5
Yeah thats all we did was trace around the old decals and then primed and painted over them. A little time and effort and a whole lot of razor blading. Came out good for krylon but the real paint job will be done once I get my tube fenders done front and rear. Thanks for the support!
boarderofsnow is offline
post #138 of 1255 Old 05-14-2011, 07:04 AM
dkbobber
I hear ya. I spaced you were doing the full size axles. Your right you should have room. You'll hit the bottom of the fender before hitting the fill neck. Its looking good and I'm looking forward to seeing on the trail again.
D Bobber
dkbobber is offline
post #139 of 1255 Old 05-14-2011, 09:06 AM
awkrueger
The build looks great. I read through the whole thing. As a YJ I feel I can relate to a build with leaf springs all the way around. Im in AZ right now on vacation away from my Jeep and I miss her. Thanks for keeping me entertained and motivated!
If guns kill people, then pencils misspell words, cars make people drive drunk, and spoons made Rosie O' Donnell fat! - stolen from Dr. Marneaus
R.I.P. - Burzum
awkrueger is offline
post #140 of 1255 Old 05-14-2011, 08:37 PM Thread Starter
boarderofsnow
1979 CJ5
Thanks man! Hope you get back to your rig real soon! I just started on my full size axles tonight....grrrrrrrrrrr
Until I get her done here is to all the others enjoying thier rigs!!!!!
post #141 of 1255 Old 05-14-2011, 08:39 PM Thread Starter
boarderofsnow
1979 CJ5
Thanks Dan! I just started on the axles tonight and WOW.....see the post below!
post #142 of 1255 Old 05-14-2011, 08:46 PM Thread Starter
boarderofsnow
1979 CJ5
Well today I started a little work on the full size axles. I wanted to lighten them up a bit before dragging them to the shop for the overhaul. All I can say is WOW!!!! 32 lug nuts never came off this hard! 3 hours PB Blasting the crap out of the lugs and standing on a cheater pipe to break the rust/torque. Here is the finish product before I drag them down to the shop in the next few days and start this next big project! Should be fun!
post #143 of 1255 Old 05-14-2011, 08:57 PM Thread Starter
boarderofsnow
1979 CJ5
Oh yeah......going to have a set of CJ axles laying around in a few weeks. Rear is an AMC 20 with an one piece kit 3.54 gears and the front is a Dana 30. Great shape from the West Coast originally. I will post something once they are out but it never hurts to market them before hand.
Probably take $500 for the set but would consider any offers.
post #144 of 1255 Old 05-18-2011, 11:18 PM Thread Starter
boarderofsnow
1979 CJ5
Alright so we got down and dirty today and cracked open the axles. First we started with the Dana 60. I am almost tempted to just do an axle build forum but I'll just toss them up here. First was the hubs. I won't badger this too much because I don't know the exact names on everything so bare with me.
Star bolts removed.
Next was pulling the locking hub cap off.
Then the screw that holds the cog and spring in.
Then the large lock ring came out.
post #145 of 1255 Old 05-18-2011, 11:26 PM Thread Starter
boarderofsnow
1979 CJ5
Next was the smaller lock ring.
At that point the rest of the locking hub assembly is ready to come out. Thread the star bolts into the holes so you can use the bolts to pull the last of the assembly out.
Once that is out its time to get to the large nuts inside. I didn't have the socket to do this. Its a specialty socket. A punch and soft hammer blows should loosen these nuts.
After the first nut is out there is a star type washer or plate behind it.
post #146 of 1255 Old 05-18-2011, 11:38 PM Thread Starter
boarderofsnow
1979 CJ5
The next nut comes off.
The bearing is the last piece in that puzzle.
At that point the only thing holding the rotor on is the brake caliper.
Dico'd the brake line.
The small bolt on the bottom of the caliper is the next to come out.
post #147 of 1255 Old 05-18-2011, 11:48 PM
jreycnc
1980 CJ5
Psshht! What a sissy wearing gloves! Wish I would actually remember to put some on when I got to work on mine. Good luck with the tons!
jreycnc is offline
post #148 of 1255 Old 05-18-2011, 11:48 PM Thread Starter
boarderofsnow
1979 CJ5
Then the plate holding the caliper on needs to get punched out.
At this point the caliper comes off and the rotor can be removed.
Once the rotor is out there will be 6 bolts to remove that hold the dust cover and caliper bracket on.
Remove them and the circle cover will come off.
Then the dust cover.
post #149 of 1255 Old 05-18-2011, 11:50 PM Thread Starter
boarderofsnow
1979 CJ5
Makes washing your hands a little easier after. Lol. Bought a box of them cause I knew what I was in for! Military Moly B and diff oil.
post #150 of 1255 Old 05-18-2011, 11:57 PM Thread Starter
boarderofsnow
1979 CJ5
The caliper bracket comes off next.
Thats the last piece holding the outer part of the hub on.
From there the axle shafts can slide out.
Here are pics of the short and the long axle shafts.
14 bolt , 5.3l vortec , atlas , cj5 , dana 60
Will`s 1979 CJ-5 Build BamaLonghorn Jeep CJ Forum 70 08-07-2011 02:35 PM
1979 CJ 5 Build up spcmac249 Jeep CJ Forum 20 07-03-2011 07:52 AM
1979 CJ5 Build TXST8tj Jeep CJ Forum 47 12-10-2009 11:25 AM
1979 CJ-7 build help RSfabrications Jeep CJ Forum 1 06-23-2009 09:30 AM
1979 CJ-5 gas tank sending unit filter Bigrey Jeep CJ Forum 1 11-10-2007 11:11 PM
