1979 cj5 Brake warning harness and reverse switch help - JeepForum.com
post #1 of 9 Old 03-02-2009, 05:27 PM Thread Starter
Muttmutt
1979 CJ5
Bought this Jeep completely apart. I have two questions. The harness coming from the proportioning valve has a plug and I have no idea where it plugs into. It is a two wire plug. Also I ordered a reverse switch for my t150 and it has a different plug. BWD S9151 is the part number .My switch has 2 blades that match the harness. The replacement has two flat slide on type deals on the top. I have searched all over for the two spade type switch. Any ideas ?? I have the old one off and the brand is Pollak but I cannot find a part number. All internet referances the S9151 switch and it is wrong for the harness.
Muttmutt is offline
post #2 of 9 Old 03-03-2009, 04:31 AM
John Strenk
John Strenk's Avatar
1976 CJ5
There are two black wires comming from the bulkhead connector that plugs right into this plug.
[img]insert picture here[/img}
Two blades? Thats different than what I've seen. I've seen two studs and two "T" type connection like I think you are describing. Does it look like your harness has been molested in any way?
John Strenk is offline
post #3 of 9 Old 03-03-2009, 06:31 AM Thread Starter
Muttmutt
1979 CJ5
The plug is factory to the reverse switch. No splice. It is the t-type connector. Do yoou know where I could find a t-type plug that I could splice in? Thanks
Muttmutt is offline
post #4 of 9 Old 03-03-2009, 06:48 AM
GPER
1979 CJ7
I can't believe I didn't write that number down, They can look it up. It is under neutral safety switch, I think for the Corvette. They have the button or the spade terminals.
I went through my receipts and the number for the neutral safety switch= back up switch for the spade connector. Auto Value or old Genuine NS18 the NAPA number is NS6578.
GPER is offline
post #5 of 9 Old 03-03-2009, 09:22 AM
GPER
1979 CJ7
So the kid and I have the flu so I have nothing else to do, this is what you are looking for right.
GPER is offline
post #6 of 9 Old 03-03-2009, 09:33 AM
Mike Romain
The prop valve has an extension chunk that goes from it to the harness up under the steering column.
Mike
Mike Romain is offline
post #7 of 9 Old 03-03-2009, 12:24 PM Thread Starter
Muttmutt
1979 CJ5
Yes that is the switch I need. Thanks I will try to get it locally. Thank again everyone.
Muttmutt is offline
post #8 of 9 Old 03-03-2009, 03:47 PM Thread Starter
Muttmutt
1979 CJ5
I took the Napa part number to the local parts store and it interchanged to a Borg Warner # S393. They even had it in stock. Thanks again. I really really appreciate the help. May have this thing on the road sometime soon. Almost ready for paint.
Muttmutt is offline
post #9 of 9 Old 03-03-2009, 04:38 PM
GPER
1979 CJ7
Glad you got it, I'll put the NAPA number in my notes.
GPER is offline
Pulled computer and wiring harness. Now I have no reverse lights jatepper Jeep CJ Forum 68 11-09-2012 01:00 PM
brake warning switch on proportioning/combination valve whittlecj Jeep CJ Forum 1 10-24-2009 07:29 AM
turn signal/hazard warning switch ado2987 Jeep CJ Forum 3 04-29-2009 10:57 AM
1979 engine harness? cj7roaddog Jeep CJ Forum 5 02-09-2007 10:34 AM
1979 Cj7 Reverse Axel Cheever1804 Jeep CJ Forum 3 08-14-2006 06:30 PM
