1979 CJ5 4.2L 3 speed transmission seal leak - JeepForum.com
post #1 of 16 Old 07-20-2013, 10:41 PM Thread Starter
jennkent5454
1979 CJ5
My transmission is leaking where the rear drive shaft goes into the tranny,
is that called the yolk?
this is where it is leaking from, right where the shaft exits the tranny. how hard is it to replace that seal? if someone knows of a write up please share it here!!!
jennkent5454 is offline
post #2 of 16 Old 07-21-2013, 06:49 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
That would be the transfercase output seal.
Drop the driveline
Remove the yoke
Pry the seal out
Carefully drive the new seal in and lube the lip
Clean the seal surface on the yoke with emery cloth and reinstall
jeepdaddy2000 is offline
post #3 of 16 Old 07-21-2013, 06:55 AM Thread Starter
jennkent5454
1979 CJ5
Is it similar to an axel shaft seal?
post #4 of 16 Old 07-21-2013, 05:15 PM
jeepdaddy2000
1971 CJ5
Number 7
post #5 of 16 Old 07-21-2013, 05:59 PM Thread Starter
jennkent5454
1979 CJ5
that seems pretty simple but I have a few more questions-
1. drop the tranny to replace the seal or do it while it is in the jeep? any tips for this?
2. I need to drain the fluid in the tranny first correct?
3. is there a tool to remove it, like the slide hammer for the axle seals?
post #6 of 16 Old 07-23-2013, 09:26 AM
SoK66
2009 JK Wrangler
You can do it with the t-case installed. Remove and install as described. Be sure to carefully inspect the bore. In many cases these have been gouged in an earlier seal replacement. The gouge will allow fluid to leak around the outside of the new seal. Use RTV on the outside of the seal to correct.
Jeeps: Where my 401(k) went to die!
SoK66 is offline
post #7 of 16 Old 07-23-2013, 09:34 AM
JeffreyCharles
1976 CJ5
Start your reading here: http://www.jeepforum.com/forum/f8/al...l#post14962860
Jeffrey Charles
http://jeep.smallcraft.net/
JeffreyCharles is offline
post #8 of 16 Old 07-23-2013, 06:16 PM Thread Starter
jennkent5454
1979 CJ5
exactly what I was looking for. thank you
post #9 of 16 Old 07-23-2013, 08:02 PM
JeffreyCharles
1976 CJ5
And don't forget to document your experience and post it for the next guy. Every little bit helps!
Jeffrey Charles
post #10 of 16 Old 07-24-2013, 02:15 PM
Jamesromeos
1979 CJ5
I did 2 seals on my tranny before replacing the yoke. 29.00 for new yoke, spend the money so you don't pull your hair out like I did for 3 months.
Jamesromeos is offline
post #11 of 16 Old 07-26-2013, 06:55 PM Thread Starter
jennkent5454
1979 CJ5
I normally get auto parts at advance auto parts. I went there today to buy the seal and we could not come up with the seal I thought I needed. here are 2 from thier website, is either of these the correct seal?
post #12 of 16 Old 07-26-2013, 07:30 PM
7CJ5White6
1976 CJ5
Well do you have the T150 or T15A?
http://www.jeepforum.com/forum/f8/1976-cj5-complete-tear-down-rebuild-1476311/
7CJ5White6 is offline
post #13 of 16 Old 07-26-2013, 08:05 PM Thread Starter
jennkent5454
1979 CJ5
T150, but it's not Borg-Warner, or tremec. Or does that not matter?
post #14 of 16 Old 07-26-2013, 08:07 PM
rah2eq
1978 CJ5
Neither of those is the correct seal. Unless your Jeep is a two wheel drive, the drive shaft connects to a transfer case. What you are looking for is a rear output seal for a Dana/Spicer 20 transfer case. This is number 7 in the exploded diagram above.
1978 CJ5 - 304 V8 - Twin Sticked and sitting on 35's
2010 JK- Rock Krawler 2.5" on 35" KM2's
rah2eq is offline
post #15 of 16 Old 07-26-2013, 08:25 PM Thread Starter
jennkent5454
1979 CJ5
here is the one I see for spicer 20, but it also says 2spd.
