1979 CJ5 2.5" or 4" BDS Lift? - JeepForum.com
post #1 of 25 Old 05-04-2011, 08:30 PM Thread Starter
EthanW
1979 CJ5
I have a 1979 CJ5 with sagging stock springs. I need new springs and I have decided I would go ahead and do a BDS lift. My question is: Should I go with the 2.5" or 4" Lift? I know i will spend a little more money with some extra parts for the 4". That is not an issue. I currenly have 31x10.50 Tires on 15x8 wheels. I also have stock AMC20 front and rear differentials. will the 4" make me too top heavy? I hope to go with 15X10 Wheels and 33x12.50 tires once my 31's wear out. Any input is appreciated.
Thanks
EthanW is offline
post #2 of 25 Old 05-04-2011, 08:59 PM
supersport126
If you plan to run 33's I would go 4''.
supersport126 is offline
post #3 of 25 Old 05-05-2011, 04:05 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Why I went with a 2-1/2" Lift
I went with 2-1/2 on my CJ5 because I still drive mine a lot on the roads. Probably about 90% of the time. And still need to plow in winter.
I have a total of 2-1/2 Spring lift, 1/2" Shackle lift and 1" body lift. I am at the limit of a u-joint angle right now and didn't have any funds left for a CV drive shaft setup that I would need if I went with a full 4" spring lift.
With the narrow track axles, I don't get any fender rubbing in or on the wheel well. If I get the wide track axles on, I may have to change some things.
Kinda adds up to 4" without the tippyness of 4" on just the spring lift.
I'm also running 15X10: rims with 33X12.5 tires.
John Strenk is online now
post #4 of 25 Old 05-05-2011, 06:44 AM
Jeepican
1976 CJ5
You dont have any idea how many times i have been back and forth on this......i can't seem to make up my mind..... i would love to see a 4" lift w/ 33 set up in person...... but cj5's with that around here are almost non existent..... i just dont want too high of a lift for the safety reasons.....
1976 CJ5 - 232 I6, MC2100, YJ Booster, Front disc conv, 2.5" BDS, 1" Body Lift, .5" lift Daystar Shackles, 33 x 10.50 BF KM2, Twin Stick
"Oh, you're just full of fun today, aren't you? Why don't we go up to the old people's home and wax the steps?"
-Barney Fife-
Jeepican is offline
post #5 of 25 Old 05-05-2011, 09:45 AM Thread Starter
EthanW
1979 CJ5
I am thinking the same thing. I don't want to make a death trap out of my jeep by making it top heavy but I don't want to regret not getting the 4 inch lift later on. I could always get some taller shackles with the 2.5 but I would rather have my lift in the springs than shackles.
EthanW is offline
post #6 of 25 Old 05-05-2011, 09:48 AM
John Strenk
1976 CJ5
Yes, shackles lifts are bad.
post #7 of 25 Old 05-05-2011, 02:02 PM
lou h
1979 CJ5
For what it's worth, here's my 79 with a 4" lift.
Dirty Juice II
lou h is offline
post #8 of 25 Old 05-05-2011, 02:05 PM
Jeepican
1976 CJ5
Are those 15x10 wheels and 33x12.50 ?
-Barney Fife-
Jeepican is offline
post #9 of 25 Old 05-05-2011, 02:56 PM
Full Tank
1980 CJ5
Here's a pic of my '80 with a 4" BDS lift. The lift only has about 100 miles on it so far so it will probably settle a bit more.
Some more details:
-no body lift
-shackles are 3/8 longer than stock so 3/16" shackle lift
-wheels are Eagle Alloy 15 x 10
-tires are Kumho 33-12.50-15 MTR's
-BDS shocks from the kit
-DC rear driveshaft from an XJ
1980 CJ5 39k
Dana 30--AMC20--D300--T176--258
Dana 30--AMC20--D300--T5--2.5L
Full Tank is offline
post #10 of 25 Old 05-05-2011, 03:01 PM
lou h
1979 CJ5
33x10.5x15
Dirty Juice II
lou h is offline
post #11 of 25 Old 05-05-2011, 03:03 PM
JeepCJ7LTD
i did a 2.5 on my cj7 and run 33 inch tires. bottom line is this, bigger than a 2.5 and it wont fit in a normal garage with a hard top and ski racks all she wrote
JeepCJ7LTD is offline
post #12 of 25 Old 05-05-2011, 03:05 PM
Jeepican
1976 CJ5
33x10.5x15
15x10 or 15x8?
Have any more pics? I'm a sucker for the skinny tires...
-Barney Fife-
Jeepican is offline
post #13 of 25 Old 05-05-2011, 03:06 PM
husker26
1978 CJ5
I went with a 2.5" and couldn't be happier! That being said, I don't drive it a ton, but when I do, it goes down the road awesome. BDS was a great choice in my book. Not that I've ever tried any other brand! I noticed a HUGE difference over the stock though. If you want to go higher than a 2.5" down the road, couldn't you do a soa to gain the difference or am I talking about something that I have no idea about
No really,, The Jeep wave really exists!!
husker26 is offline
post #14 of 25 Old 05-06-2011, 08:30 PM
Chewtoy
1976 CJ5
I have the same setup as FullTank except with 15x8 rims.
Sorry these aren't the best pics but it was a fun day.
The 4" BDS springs ride great compared to stock, but I need to warn you that their 4" springs are much closer to 5". Upside is the flex is better than most 4" springs but if you are going to do much rock crawling you will soon be looking for better flex and softer yet ride.
I have absolutely no issues with either body roll or feeling tipsy. Mind you I did add 2" wheel spacers to approximate wide track axles.
Just my 2 cents.
With a great Jeep comes an empty wallet.
Chewtoy is offline
post #15 of 25 Old 05-06-2011, 09:10 PM
benullman
1981 CJ7
SOA with STOCK springs will yield you about 5.5-6" of lift automatically. so usually you go 2.5" SUA, 4", SUA, then stock SOA, 2" SOA, 4" SOA
Ben
Originally Posted by Gregg79CJ7304 View Post
Great minds think alike, but so do serial killers......Thanks.
benullman is offline
bds , cj , kit , lift , springs
1979 CJ7 Build - "Project TRex" TRex Jeep CJ Forum 196 05-11-2014 07:02 AM
1979 CJ% with 8 " Lift what shocks do I need kluman Jeep CJ Forum 2 07-10-2010 10:51 AM
1979 CJ7 "Spartan" Build Report Jmaas Jeep CJ Forum 20 01-09-2009 08:14 PM
4" Suspension LIFT???? 1979 CJ7 swamper Jeep CJ Forum 5 07-04-2007 11:03 AM
BDS 4" Suspension Lift for a 1979 CJ5 77CobraII Jeep CJ Forum 1 02-11-2003 11:34 AM
