1979 CJ Rebuild - JeepForum.com
post #1 of 12 Old 09-20-2017, 08:38 AM Thread Starter
babyblue79
1979 CJ7
1979 CJ7 Renegade LEVI Rebuild
Jeep is a 1979 CJ7 Renegade Levi Edition. It was purchased new in 1979 by my dad and I rode home from the hospital when I was born in '81. I have driven it around town for the last 7 years or so but the 304 had gotten weak as a 40 year old motor with 90K miles should. It is basically all original with only a 3 in RC lift and 33 12.5s.
I took it to one of dads buddys that has rebuilt a few 304s and the body is going to paint today. The motor is still in limbo as to exactly what I am going to do with it. UPgraded cam is happening but unsure if I am going to change the intake and go to a 4 barrel instead of the 2. Still have not make my mind up on stock manifold exhaust vs headers. Not looking for mountain climbing power.
Anyway Ill try to keep the thread updated and will probably ask for some advice. I am not doing the work but dad is at the shop and taking pics as it goes.
babyblue79 is offline
post #2 of 12 Old 09-20-2017, 08:41 AM Thread Starter
babyblue79
1979 CJ7
SO the motor is out and taken apart. Here are some of the pics I have of getting the motor out and taking the head off. Actually in pretty good shape for a 40 year old motor that has sat up some in its life.
post #3 of 12 Old 09-20-2017, 08:41 AM Thread Starter
babyblue79
1979 CJ7
double post
post #4 of 12 Old 09-20-2017, 09:06 AM Thread Starter
babyblue79
1979 CJ7
ill figure out the pics shortly
post #5 of 12 Old 09-20-2017, 01:19 PM
ADDZ71
1979 CJ7
I have nearly the same Jeep. Just recently realized that the Wedgewood Blue color was only offered in 1979.
ADDZ71 is offline
post #6 of 12 Old 09-20-2017, 02:57 PM Thread Starter
babyblue79
1979 CJ7
Yep... Did you get a single stage paint of clear coat?
post #7 of 12 Old 09-21-2017, 07:01 AM
bob4703
1974 CJ5
Did you notice the loss of power after going to 33s? You could have gearing problem. Go here and do the math http://www.grimmjeeper.com/gears.html
Paved roads are prime examples of government over spending!
bob4703 is offline
post #8 of 12 Old 09-21-2017, 12:44 PM Thread Starter
babyblue79
1979 CJ7
The loss of power was noticeable before the change but it was more pronounced after the tire swap. It had plenty of power once it got rolling but no torque.
304
T150
D20
3.54 Gears
post #9 of 12 Old 09-21-2017, 02:38 PM
ADDZ71
1979 CJ7
Wanted to add that I shifted from Headers and Side pipes to stock manifolds and dual out the corners this past spring. Much happier with the stock manifolds. Torque and Power I would say is about equal but smell in cab and noise is more reasonable with the top off. I run a hardtop and and hard doors through the winter (Nov-Apr) and it would not matter.
ADDZ71 is offline
post #10 of 12 Old 09-21-2017, 07:59 PM Thread Starter
babyblue79
1979 CJ7
So I made the decision to make it a frame off today. Wasn't going to but I also don't want to do this again... it's just money right.
post #11 of 12 Old 10-03-2017, 08:50 PM Thread Starter
babyblue79
1979 CJ7
post #12 of 12 Old 10-03-2017, 08:54 PM Thread Starter
babyblue79
1979 CJ7
Obviously timing change worn bad. All bearing surfaces worn but the rear one was bad. Body off to body shop in the morning,
