1979 CJ-7 build help - JeepForum.com
post #1 of 2 Old 06-22-2009, 04:58 PM Thread Starter
RSfabrications
Im currently building up a cj-7 from the frame up, originally had a 258 in it, but was recently given a 4.3 tbi, was wondering what axles would people consider running?....Also if i do change the axles and need to move the perches, i was wondering to get proper angle should i mount the engine first or after the axles? i kinda need the front axle in to get proper clearance when mounting the engine, ive done swaps in cars before but nothing from ground up so im kinda new to the jeep swaps. any advice will be helpful, ill be posting pics of the build as i can. thanks
RSfabrications is offline
post #2 of 2 Old 06-23-2009, 09:30 AM
CSP
Axles aren't determined by the engine alone. Tire size, intended use of the vehicle, and driving style all play a part, among other variables.
Mount the engine first keeping in mind firewall clearance, cooling, driveshaft clearance, and steering parts in mind. The axle is about the last thing you need to worry about in relation to the engine placement. It's not a car and there should be plenty of room regarding the axle.
CSP is offline
1979 CJ7 Build - "Project TRex" TRex Jeep CJ Forum 196 05-11-2014 07:02 AM
1979 CJ7 Build Thread danheit Jeep CJ Forum 113 02-23-2010 09:20 PM
1979 CJ5 Build TXST8tj Jeep CJ Forum 47 12-10-2009 11:25 AM
1979 CJ7 "Spartan" Build Report Jmaas Jeep CJ Forum 20 01-09-2009 08:14 PM
My 1979 CJ5 Re-build/Restore 1979CJ53043SPD Jeep CJ Forum 3 11-14-2008 10:35 AM
