1979 CJ 5 Build up - JeepForum.com
post #1 of 21 Old 03-06-2010, 01:34 PM Thread Starter
spcmac249
1979 CJ5
1979 CJ 5 Build up
Well I've had this thing for about 5 years and haven't really done much with it since I got it. It came with a 3 inch lift and thats pretty much it. I stripped it down to the frame and started upgrading it until i ran into some financial hardships to say the least. Well here I am 5 years later and now have the finances to get back into it.
I started of by replacing the shackles with heavy duty lift shackles to and 1 3/4" to the lift and upgraded the shocks to the black diamond shocks. Now I purchased a 44 out of an 83ish wagoneer. After getting into the guts of it and disabling the vacuum disconnect (removed the actuator) I'm going to either weld the shaft and coupling together or replace the shaft with a solid shaft. Probably just get a new shaft for future maintenance. I am going to change the auto hubs to manual hubs this summer hopefully. I'll get some pics to post when it gets a little nicer out and i can take the tarp off.
Your ghetto sled is my speed bump!
BNB #156
spcmac249 is offline
post #2 of 21 Old 03-06-2010, 01:44 PM
LT1CJ7
LT1CJ7's Avatar
1983 CJ7
I'd loose the 1 3/4" lift shackles.
LT1CJ7 is offline
post #3 of 21 Old 03-06-2010, 03:51 PM Thread Starter
spcmac249
1979 CJ5
Just picked up an np435 wide ratio tranny for $40!
BNB #156
post #4 of 21 Old 03-09-2010, 06:12 PM Thread Starter
spcmac249
1979 CJ5
After talking to the wife, she has agreed to let me spend $2500 on the CJ for now. Thats a good thing since it's going to cost me about $1400 to get the 44 set up and installed. I'm replacing the DS inner with a chrome moly inner, new inner and outer bearings, figured i wouldn't risk using the old ones when new ones are only $16. I'm also replacing the auto hubs with manual hubs, and an OX locker. Everything was going good (cheap) until i decided on an ox locker. Oh yeah and the steel plate to putboard the springs for the axle.
BNB #156
post #5 of 21 Old 03-14-2010, 03:36 PM Thread Starter
spcmac249
1979 CJ5
I think I should rename this thread to "Extreme Makeover Jeep Edition"
BNB #156
post #6 of 21 Old 07-06-2010, 05:14 PM Thread Starter
spcmac249
1979 CJ5
Well got some plate steel and started working on outboarding the front springs. Got the new mounts bolted and welded on to the frame saturday. working on getting the spring mounts off the frame and moving them out. at last making some kind of progress on it!
BNB #156
post #7 of 21 Old 07-18-2010, 01:28 PM Thread Starter
spcmac249
1979 CJ5
got the front shackle mounts attached and painted. Now i'm working on the spring mounts. got the right one off. i think i'm going to bolt it onto the spring so i can get it exactly where i need it.
BNB #156
post #8 of 21 Old 07-19-2010, 04:29 PM Thread Starter
spcmac249
1979 CJ5
picking up the 44 rear this week.........hopefully!
BNB #156
post #9 of 21 Old 07-20-2010, 08:37 AM
4lowherewego
1979 CJ7
I love my 44 rear =) Glad to see you getting your 5 together how you want it.
4lowherewego is offline
post #10 of 21 Old 07-24-2010, 01:42 PM Thread Starter
spcmac249
1979 CJ5
getting ready to out board the front spring mounts. thinking about adding 1 3/4" to them to correct the axle angle because of the shackles lift i put on. one question...:.will that add to my lift?
BNB #156
post #11 of 21 Old 07-26-2010, 07:50 AM Thread Starter
spcmac249
1979 CJ5
measured how much lift i'll get by adding 1 3/4" to the spring mounts. It'll be about 1" more lift. that'll bring me to 6" of lift.
BNB #156
post #12 of 21 Old 07-26-2010, 06:52 PM Thread Starter
spcmac249
1979 CJ5
got my 44 rear tonight! pretty soon the jeep will be sitting with a new stance! i can't wait to see it.
BNB #156
post #13 of 21 Old 07-28-2010, 06:09 PM Thread Starter
spcmac249
1979 CJ5
Finlly got some pics downloaded. here is my baby before the surgery began. She still has the 30 front and 20 rear in these.
BNB #156
post #14 of 21 Old 07-28-2010, 06:18 PM
Kman1983
1983 CJ5
Looks like your using an intermediate tub. What did you do to fit it to the '79 frame?
Rolled Red Jeep Club Member #258
'83 CJ5, 4.0 MPFI swap, T18/D20, CenterForce II clutch, Dana44/30(73 CJ5) with 3.73's,'79 knuckles and 11" discs, sagged 4" lift, 2" BL, 34x9.50x15 Super Swamper Pizza Cutters
My wifes website The Vermont JeepGirl http://www.vermontjeepgirl.com/
"Good Girls and Dirty Jeeps" a song by Opal Justice http://youtu.be/9xRtRE45OVQ
Kman1983 is offline
post #15 of 21 Old 07-29-2010, 05:35 AM Thread Starter
spcmac249
1979 CJ5
Its a 72 frame and tube. When I bought it from my buddy he told me it was a 79. I didn't bother looking at the VIN until after I started working on the axles. Thats when I looked at the VIN on the tub and frame.
BNB #156
1979 CJ7 Build Thread danheit Jeep CJ Forum 113 02-23-2010 09:20 PM
1979 CJ5 Build TXST8tj Jeep CJ Forum 47 12-10-2009 11:25 AM
1979 CJ-7 build help RSfabrications Jeep CJ Forum 1 06-23-2009 09:30 AM
1979 CJ7 "Spartan" Build Report Jmaas Jeep CJ Forum 20 01-09-2009 08:14 PM
My 1979 CJ5 Re-build/Restore 1979CJ53043SPD Jeep CJ Forum 3 11-14-2008 10:35 AM
