1978 J20 drive train swap into 79 CJ5 ??? - JeepForum.com
post #1 of 9 Old 07-29-2013, 08:09 AM Thread Starter
billiardking
Would the axles , T18a tranny and transfer case
Swap into a stock 79 CJ5 what I'm asking is without any severe modifications I want to keep
CJ safe and streetable I need a motor and found a 78 j20 with good motor and 4 speed tranny and 3:73 gears with a Dana 60 rear and Dana 44 front
Just don't know the jeep axles just but
billiardking is offline
post #2 of 9 Old 07-29-2013, 08:19 AM Thread Starter
billiardking
Little more info I can move spring hangers and perches if needed just didn't know if these jeep axles under a j20 are two wide for the CJ5 but for a little more money than I was already gonna spend for motor I can get this jeep truck and use motor and drive train to upgrade from 3 speed to 4 speed and get 3:73 gears and a wider stance
Plus Dana 60 is Suppost to be a posi trac
Not looking for a how to just is this a common swap and can I still send the old lady to get groceries in the CJ5 when its done and not worry about it being safe
Any thoughts and info would be great
Thanks
post #3 of 9 Old 07-29-2013, 08:47 AM
benullman
1981 CJ7
where are you located? I might be interested in the j20 body/frame
Ben
Originally Posted by Gregg79CJ7304 View Post
Great minds think alike, but so do serial killers......Thanks.
benullman is offline
post #4 of 9 Old 07-29-2013, 09:05 AM Thread Starter
billiardking
I'm in OKLAHOMA
post #5 of 9 Old 07-29-2013, 09:10 AM
benullman
1981 CJ7
Originally Posted by billiardking View Post
I'm in OKLAHOMA
well darn, little to far for me!
post #6 of 9 Old 07-29-2013, 12:30 PM
CSP
If the J-truck has/had a V8 the input shaft of the transmission is going to be way too long for you to use it. The shifter would end up between the seats.
CSP is offline
post #7 of 9 Old 07-29-2013, 12:41 PM
jeepwhore
And the axles are going to be much wider than the stock CJ axles.
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #8 of 9 Old 07-29-2013, 01:27 PM Thread Starter
billiardking
Ok thanks guys that's the info I'm looking for
So even tho my cj5 was factory with a 304 the tranny from jeep truck is pushed back future than the cj5 three speed ??
I was wondering about the axles but will probily pass on the j20 setup and just go with rebuilt motor and keep my stock axles and tranny for now
post #9 of 9 Old 07-29-2013, 01:42 PM
jeepwhore
Thats right. The T18 used in the Jeep trucks and wagons had a much longer input shaft and bellhousing. So it can't be used in a CJ without swapping the input shaft.
