Considering a CJ7 "Golden Eagle" What should I look for?
It has the 6 cyl, 3 speed plus low. Looks like the manual shift transfer case, 4h 4l 2h. Old, but usable tires with much tread. Soft top is very weathered and brittle. Steering column wobbles a lot (like a bearing is out just below wheel) , and the wheel has been replaced, horn button wired on dash. Odometer showing 30,000. Tub is rusty on floor boards, but not through. Someone has put a different air cleaner on. . . And the power steering pump and bracket dont look orig. Owner says it "runs good" and gets down the hiway.
He wants $3500.00
I'd say more like 22 at the max. . .
