1978 cj7 problem going int 4 wheel drive - JeepForum.com
post #1 of 8 Old 12-24-2008, 10:29 AM Thread Starter
extremecj7
1978 CJ7
When I first received my cj7 I trioed the 4x4 out and it dident seem to work then a few weeks ago I tried it out again and it worked tried it last night couldent get it to engage I locked the front and put the lever in 4hi and I tried low any tips greatly apritiated .............................
HAPPY HOLIDAYS
mud pits are like a hot chick w/ std's,you wanna hit it, but your scared of the consequences
extremecj7 is offline
post #2 of 8 Old 12-24-2008, 11:13 AM
j33pman
is this a quadratrac?
If so check your vacuum lines
Bill H. - 1984 CJ-7
Now with Fiberglass!
j33pman is offline
post #3 of 8 Old 12-24-2008, 11:25 AM Thread Starter
extremecj7
1978 CJ7
How would I know if its a quadra trac thanks
post #4 of 8 Old 12-24-2008, 11:33 AM
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
Well at least you filled out your Jeep profile, so we can get a little bit of info there. 304 with a 3 speed, any idea what TC you have? I'll start by asking are you moving or sitting still when you are trying to shift?
Give MORE info.
United States of America
Born: July 4, 1776
Died: Nov 4, 2008
SUICIDE
SlikRic is offline
post #5 of 8 Old 12-24-2008, 11:44 AM
bigjoe
1977 CJ7
2x's on moving or sitting. Helps sometimes to moving a little forward while trying to engage 4wheel drive. Also helps sometimes to have tranny shifted into neutral and clutch engaged. Just a thought.
Seems like everyday is a Monday.
77' CJ-7 83' Chevy K10
bigjoe is offline
post #6 of 8 Old 12-24-2008, 12:19 PM Thread Starter
extremecj7
1978 CJ7
I tried it parked with clutch in then went forwarrd then backwads that dident help
I heard I should try keeping it in 1 let the clutch out and then move the shifter into 4x4 they said it might syncronize ....
And I'm not possitive what tc I have I just looked online quick maybee a dana 20 does that make sense thanks
post #7 of 8 Old 12-24-2008, 03:09 PM
JavaTee
1979 CJ5
Make sure your shifter boot isn't interfering with the attempt of pulling it into 4wd. When I had a Dana 20 tc (your photo shows locking hubs, and you mentioned 'shifting' - so it sounds like you have a Dana 20), usually I would roll a little bit, tranny in gear, clutch petal pushed, and I would give the lever a slight 'push' or 'pull', then sometimes swear, and attempt it again. Typically the swearing factor would help it engage.
Later, T.J.
JavaTee is offline
post #8 of 8 Old 12-24-2008, 10:14 PM Thread Starter
extremecj7
1978 CJ7
Thanks for all your input today I was out testing everyones theories and I paid a little more attention to the t.c shifter and noticed it would slowly creep back into 2 wheel drive.... I might have to cut the floor a lil so it pulls back more that might help ........BUT NEW PROBLEM before today I was driving the jeep in 4 lo with out the hubs locked wich isn't a bad thing but I started to drive with it in 2 wheel drive on the t.c and it makes a whinning noise and pops out so I just stuck it in 4 low it doesn't wine in their and it doesn't feel like it pulling back ....so is that a bad desicion to keep the t.c in 4 lol with the front end in 2 wheel ...thanks again I'd be lost with out my fellow jeepers ..
Jeep Cj7 4 wheel drive light problem funinfuneral Jeep CJ Forum 7 07-20-2007 01:30 PM
Distributor Problem - 1978 CJ5 428L DaveO39 Jeep CJ Forum 3 04-01-2007 07:52 PM
no 4-wheel drive bdruff Jeep CJ Forum 15 01-24-2007 07:29 AM
Didn't want to go into four wheel drive... 390fastback Jeep CJ Forum 2 12-15-2005 08:15 AM
1978 CJ5 Carb problem Old_man_emu Jeep CJ Forum 3 06-18-2002 08:41 AM
