1978 CJ7 Dash Lights Quandry - JeepForum.com
 1Likes
  • 1 Post By HackFabrication
post #1 of 10 Old 08-05-2012, 01:16 AM Thread Starter
xnodesirex
1978 CJ7
long time listener, first time caller here...
Just got a 1978 CJ7 that I love, but as I'm slowly working out her kinks, the wiring has got me.... lost.
Spent the last 4 hours or so backtracking, deleting back wiring done for the sound system, etc. As of right now, I still cannot figure out why the dash lights do not work.
A few bulbs do work, though the rest were left absent from the PO. I have not replaced the light switch, though I 'jumped' from the hot to the dash lights in the light switch block and nothing happened. Just for fun I tried the headlights via the same method, and they work. So it's something dedicated to the dash lights.
edit: I tried replacing the fuse (used a 5amp instead of 3, but it should be a-ok). No help there.
I have tried backtracking the ground, I hear this is the most common solution. All of the dash lights are single orange wires, and I cannot figure where on earth the ground comes from.
In wiring diagrams, I do see that the ground links up to a degree with the lights for the a/c, etc. but no place that it directly links up with the dash lights themsleves. What am I missing here??
I know a lot of people have just "added" ground, but where on earth in the chain would I do this??
TL;DR - dash lights won't work. Can't find ground.
xnodesirex is offline
post #2 of 10 Old 08-05-2012, 05:42 AM
wkp
1980 CJ7
You can just run a temporary wire from the neg terminal of your battery and connect the other end to any bolt on your dash. If the lights then work, you know you have a bad ground and you can then run a NEW permanent ground to your dash. If they don't work, then you might want to see if you are getting 12V of power through your "orange" wires that go to your dash lights. Also, make sure that your "dash light dimmer" switch is not scrolled down in the full dim position.
wkp is offline
post #3 of 10 Old 08-05-2012, 06:04 AM
johninmichigan
1979 CJ7
I just went through almost the same thing with my 79 I removed the headlight switch and sprayed it with electrical cleaner. that fixed my problem but it does not seem to be yours as some of them work. I believe each individual light gets it's ground through the gauge it's mounted in. so maybe by pulling each and using a little sand paper in the mounting hole you'll reestablish your grounds again. It's worth a try. John
John in Michigan (Back in Horseheads NY) '79 CJ7, 2012 Chevy Malibu. 07 Nitro,
johninmichigan is offline
post #4 of 10 Old 08-05-2012, 07:43 AM
skizriz
1978 CJ7
Here's a diagram that may help you along. Some of the dash lights have their own ground, some ground to the gauge.
There are also other orange wires that aren't for the lights. One comes off of the switch and goes to a dome light of some sorts. Another goes to the 4wd light.
skizriz is offline
post #5 of 10 Old 08-05-2012, 08:57 AM Thread Starter
xnodesirex
1978 CJ7
Hey All,
Thanks for the responses!
Fairly confident it is NOT the ground. Tried replacing it, no luck.
I checked at the fuse panel, and without a fuse I am able to get 12v terminal to terminal with the lights engaged. So that checks out.
Unfortunately, when I then go check the individual lights, I maybe get 0.02v. So something is not hooked up right, though for the life of me I can't figure it out since so much of the wiring is bound together (factory I assume). Could it be something on the other side of the fuse panel that I don't see??
post #6 of 10 Old 08-05-2012, 09:10 AM Thread Starter
xnodesirex
1978 CJ7
oddly enough, the only light that DOES work is the high beam indicator on the speedo.... wired totally differently from what I see in the wiring diagram... so I'm completely stumped.
post #7 of 10 Old 07-29-2013, 09:20 PM
dirtyseay
1978 CJ7
Hey I have a 78 cj 7 and it is doing the exact same thing. did you find the cure?
dirtyseay is offline
post #8 of 10 Old 11-04-2015, 07:29 PM
Oregonwheeler
Cj
Oh Boy, I was hoping to find an answer here. I am having the same problem and don't seem to be getting anywhere. The orange wire coming off the switch is hot all the time. Are the dash lights supposed to be lit all the time?
Then, testing the sockets, I am getting no voltage.
Oregonwheeler is offline
post #9 of 10 Old 11-04-2015, 07:46 PM
HackFabrication
HackFabrication's Avatar
1976 CJ5
Old thread but worthy of this:
Originally Posted by xnodesirex View Post
...I cannot figure where on earth the ground comes from.
streetpro likes this.
"In the end...It's all Hack."
HackFabrication is offline
post #10 of 10 Old 11-04-2015, 08:50 PM
Jeep-N-0311
XNODESIREX Here's some info for step by step troubleshooting:
JOHN STRENK:
http://www.jeepforum.com/forum/f8/jo...blems-1309086/
(See 5th post down) - click on the links at the bottom of his post; educational and may provide the solution
(A good one >>) http://civilianjeep.info/Strenk/Gaug...for_cj_gau.htm
JEEPHAMMER
http://www.jeepforum.com/forum/f8/en...rounds-491290/
Jeephammer starts 2nd post from top - again, in addition to the actual post (& follow-ons in the thread), see his hotlinks at the end of his post
His home web page - http://www.junkyardgenius.com/toc.html
1 circuit at a time, trace it from "power-in, through the switch, through the gauge/light, and back to ground". Use a 12V indicator light (at minimum), a meter is better. As others have pointed out, cleaning / emery or brushing contacts helps. Additionally, Good grounds and once you have proven a circuit (got it working), solidifying and protecting it (i.e. electrical + mechanical + waterproofed connections, and dielectric grease at appropriate locations) means not having to go back and fix it one cold, wet night.
Jeep-N-0311 is offline
dash lights , ground , wiring
CJ7 price quandry KingsRiverKid Jeep CJ Forum 3 06-05-2011 07:54 PM
rear end quandry jpfix Jeep CJ Forum 8 03-03-2010 08:14 PM
lift kit quandry 79cj7reny Jeep CJ Forum 16 04-18-2007 09:20 AM
no brake lights and no dash lights boydog40 Jeep CJ Forum 6 03-01-2006 06:49 PM
SOA Quandry crazyjeeper69 Jeep CJ Forum 6 07-31-2004 10:57 AM
