1978 CJ7 304 V8 MC2100 Carb Problems - JeepForum.com
post #1 of 6 Old 11-04-2011, 04:53 PM Thread Starter
CJ7ville
1978 CJ7
I have a 1978 CJ 7, with a 304 V8. I believe it has a MC2100 Carb, when i started it today it all of the sudden runs like crap, i took the breather off to find after running for ten sec the two large holes on top starting to bubble fuel which then ran down in bowl....flooded it out!!! Is this a stuck float?
CJ7ville is offline
post #2 of 6 Old 11-04-2011, 07:10 PM
h2ogun
That would be my first guess, and I would start there.
That model engine should have a newer carb that should have an overflow line (and not the two holes) that connect to the canister, but it could have been changed. (but should still work fine.)
As well, there is a possibility that the fuel filter just before the carb has been changed. The filter should have one input (from the fuel pump) and two outlets, the large one going to the carb and the smaller is fuel return line (smaller diameter) that goes back to the fuel tank. The fuel filter should be positioned so that the return line is directly above the discharge line. While it is a complete shot inthe dark, that could contribute to the problem.
h2ogun is offline
post #3 of 6 Old 11-08-2011, 09:39 AM Thread Starter
CJ7ville
1978 CJ7
Thank You for the great info!
CJ7ville is offline
post #4 of 6 Old 11-08-2011, 11:22 AM
CJ5_Fan
CJ5_Fan's Avatar
1980 CJ5
Prior to this incident, did it run correctly? If yes, and you didnt do any mods to it, then I would not worry about having something hooked up incorrctly and would focus on the operation of the carb itself. If no, then you may have issues elsewhere.
1980 CJ5 Renegade with 304 v8
CJ5_Fan is offline
post #5 of 6 Old 11-10-2011, 04:17 AM Thread Starter
CJ7ville
1978 CJ7
It ended up being stuck float!
CJ7ville is offline
post #6 of 6 Old 11-10-2011, 08:29 AM
bigjoe
1977 CJ7
HA! I have the same issue on one of my Jeeps here. Is doing the same thing. Float being stuck was one of my first things to check. But I may have water in my tank as well. Glad your Jeep's back in service.
Seems like everyday is a Monday.
77' CJ-7 83' Chevy K10
bigjoe is offline
1978 Carb Connector ??? marcaurell Jeep CJ Forum 6 03-24-2011 02:15 AM
1978 258 carb question jimdubose Jeep CJ Forum 8 03-13-2009 05:10 PM
1978 CJ5 232 straight 6 needs a new carb CJ5Durham Jeep CJ Forum 3 01-30-2009 01:36 PM
Carb ? Carter from 1978 CJ-5 on 85 CJ Geer_hed Jeep CJ Forum 1 05-04-2004 07:52 AM
1978 CJ5 Carb problem Old_man_emu Jeep CJ Forum 3 06-18-2002 08:41 AM
