1978 cj5 need instructions for installing 3 point seatbelts onto rollbar...help plz - JeepForum.com
post #1 of 5 Old 07-21-2009, 01:06 PM Thread Starter
junksauce
i bought seatbelts and the instructions that came with them were horrible, i could use help knowing which parts go where and how im supposed to attach these seatbelts onto my rollbar...ie. do i have to drill all the way through my rollbar or what? please help, links or advice would be much appreciated.
junksauce is offline
post #2 of 5 Old 07-21-2009, 01:13 PM
jeepskate
You need to drill all the way through, weld in a sleeve, then bolt through the sleeve.
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
jeepskate is offline
post #3 of 5 Old 07-21-2009, 01:52 PM Thread Starter
junksauce
ok thank you, also where do i put the retracting mechanism? i have a fiberglass body and so im not sure if there is a specific spot on the jeep, do i mount it on the wheel well or the floor? and are there any pictures or diagrams of this available?
post #4 of 5 Old 07-21-2009, 02:14 PM
CSP
Are these factory seatbelts or some other type?
Some retractors work when mounted parallel to the vehicles direction of travel. Others work mounted at 90 to the direction of travel.
Hard to tell where they mount with the info provided.
CSP is offline
post #5 of 5 Old 07-21-2009, 03:22 PM
monninen
1974 CJ5
I am trying to do the same thing soon. No hijack - just a quick question: is the bolt long enough that you will put through the cage ?
monninen is offline
Changing a CJ rollbar to a YJ family style rollbar Bard Jeep CJ Forum 110 03-25-2017 06:03 PM
3 point shoulder style seatbelts for 77 cj7? DeadPhish Jeep CJ Forum 9 01-31-2012 07:22 PM
TJ seatbelts in a CJ calcallender Jeep CJ Forum 1 07-06-2008 07:57 AM
Need Instructions for OEM CJ5 Soft Top 1978 5StarRising Jeep CJ Forum 17 10-19-2007 04:27 AM
3 point seatbelts for a CJ-5? wwhitby Jeep CJ Forum 2 07-28-2006 05:59 AM
