1978 cj5 i sit to high - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > 1978 cj5 i sit to high
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineYear End Clearance Sale! Save 20%Warn, Smitybilt, Engo, Rugged Ridge Winches at CCOR
Unread 12-18-2014, 07:52 PM   #1
Tanker205
1978 CJ5
I just bought a 78 CJ5 and my head rubs on the bikini top, the bikini top is all I have. I`m not really all that tall, 6 foot. What can I do? is this a common issue?
Tanker205 is offline   Reply With Quote Quick reply to this message
Unread 12-18-2014, 08:08 PM   #2
jeepdaddy2000
1971 CJ5
Drop the seats.
space the bikini top up off the roll bar. This can be done using water pipe insulation and wide electrical tape.
slouch........
jeepdaddy2000 is offline   Reply With Quote Quick reply to this message
Unread 12-18-2014, 08:10 PM   #3
Jeff88
Could also cut a big hole in the top and just stick your head through it.
Jeff88 is offline   Reply With Quote Quick reply to this message
Unread 12-18-2014, 08:11 PM   #4
dg6772
If your seats are not jeep seats, they may be sitting higher causing your issue. My friend had this problem and he is only 5'10". Turned out he had Ford escort seats. They added a lot of height.
Dave in Muskegon using JeepForum app
dg6772 is offline   Reply With Quote Quick reply to this message
Unread 12-18-2014, 08:19 PM   #5
wellmax
my old jeep has one of those black padded raps on the roll bar.
it makes the roll bar look much better during the summer and it also adds about 1" of height to the soft top
it is a foam type material that wraps around the bar with a cover that zips over the wrap, looks much better than the bare bar and would be much softer, if you head ever hit the bar in a bump situation.
wellmax is offline   Reply With Quote Quick reply to this message
Unread 12-19-2014, 07:39 AM   #6
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
You probably have aftermarket non-CJ seats. Many of them sit a lot higher than factory seats.
You can either modify the seat brackets, or find seats with a thinner butt pad.
Matt
Matt1981CJ7 is online now   Reply With Quote Quick reply to this message
