1978 CJ5 front hub removal - JeepForum.com
post #1 of 7 Old 08-03-2004, 01:04 PM Thread Starter
daplaya
Question 1978 CJ5 front hub removal
Went through some pretty deep water this weekend. Need to repack bearings. Anybody know a good site that shows removal and installation and any special tools required? Also, what are other areas other than differentials, XMSN, transfer case I should check for water?
Thanks.
daplaya is offline
post #2 of 7 Old 08-03-2004, 01:44 PM
ravinhuxley
Dana 30? tencharacters
'85 CJ-7
258|T-176|TFI|Weber 38 DGES w/Spacer|2" body lift|Centerforce clutch|A20|D30|32" BFG MTs|Red, of course
ravinhuxley is offline
post #3 of 7 Old 08-03-2004, 02:19 PM Thread Starter
daplaya
Yes, DANA 30
daplaya is offline
post #4 of 7 Old 08-03-2004, 03:32 PM
weedy
weedy's Avatar
You must be new to four wheel drive machines if you are unable to repair your leaking hub. Sounds like you need to keep it out of waste deep water. Good luck.
weedy is offline
post #5 of 7 Old 08-03-2004, 04:16 PM
j-man
j-man's Avatar
ten characters
1988 Red Wrangler
2.5L 4 banger
soft top, half doors
pioneer cd deck, sony xplode speakers
cragar rims/30" continental
soon to come:
2.5 spring lift
1" body
31" tires (i like fender clearance :) )
Red Jeep Club #297
j-man is offline
post #6 of 7 Old 08-03-2004, 04:28 PM Thread Starter
daplaya
What is ten characters?
daplaya is offline
post #7 of 7 Old 08-03-2004, 06:34 PM
fuzz401
1978 CJ7
wheel bearings pull the hubs - there might be a snap ring on the end of the axel - the nuts you can use a chisel to remove the 1st nut the plate behind it is bent to fit the flats on the nut must be bent back to allow the nut to turn free - 2nd nut same as 1st - pull hub and rotor off -rear -tranny - tc drain add new oil
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
correct front end caster on a 1978 cj7 dennism1960 Jeep CJ Forum 8 03-11-2010 07:37 PM
Waggy Front D44 removal omanalansanjr Jeep CJ Forum 6 05-13-2009 10:54 AM
CJ 5 Front Drum removal Krackalacka Jeep CJ Forum 4 01-25-2009 12:40 PM
Front drum removal on 66 CJ5 jeeprookie47 Jeep CJ Forum 4 09-10-2008 10:00 AM
CJ OEM Front Bumper Removal TOBYWON Jeep CJ Forum 6 11-23-2007 09:08 AM
