04-18-2010, 09:20 PM
#1
I just picked a '78 CJ7. Unfortunately I was just informed that the person I bought it from "put a CJ7 body on a CJ5 frame"...is that possible?
It appears I'm missing quite a bit...ie, the fuel vapor canister, check valves, firewall grommets, half of the a/c is missing, there are vac lines tied in a knot & plugged with a screw, non-existent vac lines, windshield washer jets & thats just off the top of my head.
Does anyone know where I can get any of what I mentioned, or a parts manual & maybe some pictures from under the hood of a similar year & engine?
04-18-2010, 09:30 PM
#2
lol Those missing parts remind me of my jeep, its missing the same things, Im not sure where you can get those parts. but i dont think a cj7 will go onto a cj5 frame.
Jeep # 1 - 1947 CJ2a - Restoration in progress...very slow progress
Jeep # 2 - 1983 CJ7 - 31x10.5R15 Pro Comp Extreme mt's - 4.0 HO head - MC2100
Jeep # 3 - 1990 Cherokee - 4.0, AW4, dana 30 HP, dana 35 -31x10.5 R15 mud terrains, 2" PNP lift..... Gone to the crusher
Jeep # 4 - 1999 wj stock and still pretty
#3
It is not possible unless there has been some serious fabrication. The CJ7 wheel base is longer.
Quadratec of 4wd Hardware are good sources for Jeep parts. The FSM is here on JF, which has all the parts.
1985 Jeep CJ-7
Automatic-258 I6- Detroit lockers front/rear - Superior 1-piece axles, Ramsey Pro 9000 Winch, Quick Disconnects, 33 BFG AT's, 4.10 gears, Howell TBI, DUI HEI Ignition, Ground Pounder Rear Bumper / Tire Carrier Combo, Handen Fab integrated winch plate front bumper w/hoop, ORF weld-in front sport cage.
USMC 1999-2004 Semper Fi!
Hood Hi-Lift Jack Mounts for CJ/YJ/TJ/JK
Torchmate CNC Plasma Table Build / Projects
The Target Man, LLC - AR500 Shooting Targets
04-18-2010, 09:32 PM
#4
A picture is worth a thousand words.
If you can't be handsome, you'd better be handy.
04-19-2010, 08:50 AM
#5
yep- post up a few pics of what you've got, and we can help you.
a more common (but still not too COMMON) swap is a CJ5 tub on a CJ7 frame (for extended wheelbase)
Hoss
It's hard to say no to yoo-hoo, the name literally beckons...
Don't mind me, I'm just another FNG around here...
04-19-2010, 09:11 AM
#6
Thanks, all of you...I'm a complete newb when it comes to forums, this is my first.
jatepper, you mentioned FSM, now I figured that JF is jeep forum, but what's FSM?
I'll have pictures up by 8pm tonight EST.
Also, are all fuel vapor canisters the same?....can I use one of of a later year? I cannot, for the life of me, find one for a 1978 CJ7.
04-19-2010, 09:19 AM
#7
FSM = Field Service Manual. These things will all become second nature to you once you've fully submersed yourself in your new project.
1979 Jeep CJ7
Follow My Build Thread: http://www.jeepforum.com/forum/f8/1979-cj7-build-project-trex-935022/
04-19-2010, 09:29 AM
#8
Awesome, thanks again...LOL, the deeper I delve into it, it's definitely starting to look like a project. I was hoping to drive it sometime this year tho,  . jatepper mentioned that the FSM was available here? Does that mean I can view it thru jeep forum?
04-19-2010, 09:37 AM
#9
Muddin Maniac
Here's one for 76 model, should be pretty close for now.
Jeep® 1976 TSM online
United States of America
Born: July 4, 1776
Died: Nov 4, 2008
SUICIDE
04-19-2010, 09:52 PM
#10
Well, here is a few pics of what I have...do not say, I did not warn you....lol
I drove it for the first time today, I most likely need an entire new front end...joy-
Thanks again everyone, any advise/help would be appreciated.
04-20-2010, 08:05 AM
#11
ummm...................any chance you could post a pic of the OUTSIDE of the Jeep?
Hoss
