1978 CJ Windshield help - JeepForum.com
post #1 of 5 Old 01-24-2013, 03:51 AM Thread Starter
winy68
1978 CJ5
I had to buy a new windshield fram which is installed onto the jeep with mix match bolts (long story, my son's project ) some had torx heads i believe some were regular bolts.
If anyone could let me the the number and size of each so I can properly install the windshield from - I'd appreciate it
Thanks in Advance
winy68 is offline
post #2 of 5 Old 01-24-2013, 06:43 AM
keith460
Jeep. There's Only One
keith460's Avatar
They are all 5/16-18 x 1" Flathead Torx screws.
Some guys replace them with Allen Head screws but the diameter of the head itself is slightly larger than the OEM Torx screw type. Which means the Allen head screws will not be completely flush with the surface of the hinges when tightened down.
1984 CJ-7 Renegade
keith460 is online now
post #3 of 5 Old 01-25-2013, 01:31 PM
2Xtreme
2Xtreme's Avatar
1979 CJ7
Some guys replace them with Allen Head screws but the diameter of the head itself is slightly larger than the OEM Torx screw type. Which means the Allen head screws will not be completely flush with the surface of the hinges when tightened down....
That being said, the hinges could probably be re-countersunk to accept the allen head screws
2Xtreme is offline
post #4 of 5 Old 01-25-2013, 02:08 PM
keith460
keith460's Avatar
Not really.
The hinges are probably about 3/16" thick and standard flathead screw heads for 5/16" are right around 1/4" thick or height. You could counterbore the hinges a little more but screws would bottom out on the sheet metal and or threaded nut or plate below the hinge. I tried this on my old tub and on a old hinge when I was considering changing over to all stainless steel flathead screws. I abandoned the idea once I saw the screw heads still poking above the hinge and now loose because I counter sunk the holes a little more.
1984 CJ-7 Renegade
post #5 of 5 Old 01-25-2013, 06:46 PM
82JeepCJ7
1982 CJ7
I'd rather have a little bit of Allen head sticking out than the thought of ever putting a torx POS back on my Jeep. Mine sit flush.
I just replaced the windshield frame on my CJ about 2 weeks ago. I bought 8 of the counter sunk Allen head bolts. 5/16x1" is the correct size. I also replaced the bolts with stainless that hold the windshield hold down onto the frame. I used 3/8x1" countersunk to hold it to the dash. I put anti-seize on all the threads. I did put some black RTV between the hinges and the frame to keep water out.
When I put the new cowl seal on, it was very "inflated" to the point I had to use a ratchet strap from the top corners down to the seat frame to pull it back enough to get the hold down bolts in. Once it was down, everything fit perfectly.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
frame , hinge , windshield , windshield bolt
