1977 Jeep Cj5 won't start - JeepForum.com
 14Likes
post #1 of 42 Old 04-17-2017, 01:12 PM Thread Starter
Bluefire35
Bought a 77 cj5 and started up fine when I bought it but I changed the spark plugs the cap ,the coil for a tune up and it won't start now
Sent from my HTC One M9 using Tapatalk
Bluefire35 is offline
post #2 of 42 Old 04-17-2017, 01:48 PM
STJP
STJP's Avatar
Blue,
Have you checked to see if you are getting spark at plug wires?
Could you have accidentally disconnected wires?
Send pictures of wires, distributor, and someone here will be able to help you.
JS
STJP is offline
post #3 of 42 Old 04-17-2017, 02:05 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Wrong firing order perhaps?
Matt
Matt1981CJ7 is offline
post #4 of 42 Old 04-17-2017, 02:54 PM Thread Starter
Bluefire35
Got the order right checked all the wires and got the gap at .035 not sure if they are all firing though
post #5 of 42 Old 04-17-2017, 06:49 PM Thread Starter
Bluefire35
Top, left and right view
post #6 of 42 Old 04-17-2017, 07:35 PM
WapitiJ
Not being a smartass but you do realize the positive battery cable is diconnected in your pictures. I assume you do but you never know.
Sent from my SM-G900V using Tapatalk
pochej likes this.
WapitiJ is offline
post #7 of 42 Old 04-17-2017, 07:36 PM
NittanyGen
Even if youre not firing on a cylinder or two, you should at least have some sort of signs of life. Does it try to run at all, or just continuous crankspin with no fire?
Pull one plug and make sure you're getting good strong spark, that will rule out a defective coil. Are you getting fuel to the carburetor?
NittanyGen is offline
post #8 of 42 Old 04-17-2017, 07:56 PM Thread Starter
Bluefire35
Coil is new and Yea I get spark. When I crank it it sounds like it wants to start but doesn't turn over
post #9 of 42 Old 04-17-2017, 08:55 PM
pedal2themetai
1956 CJ5
Hi, did you change the rotor or at least clean it? Now spark, fuel and air is all that is needed to run.. if you know you have spark then dump some fuel into the carb and see if it starts.. if it does not start then you have the firing order off. do you have the right rotation on your firing order CW or CCW.
good luck
tim
pedal2themetai is offline
post #10 of 42 Old 04-18-2017, 07:22 AM
Matt1981CJ7
1981 CJ7
If you've got spark at every plug while cranking, then it's gotta be fuel related.
As Tim said, dump some fuel in the carb (about a shot glass worth), or use starter fluid. If it fires and runs briefly, then suspect a bad fuel pump, a clog or air leak in the fuel lines, or a plugged up fuel filter.
Matt
post #11 of 42 Old 04-18-2017, 08:47 AM
Fourtrail
1974 CJ6
Were are the wires that should be hooked up to the other terminal on the starter solenoid? Looks like the red pair are hanging below? You may get a weak spark when cranking, but without a full 12v to the coil while cranking, it might not be enough to get the motor started.
pedal2themetai likes this.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
post #12 of 42 Old 04-18-2017, 01:20 PM Thread Starter
Bluefire35
Matt
I've tried starter fluid but it still doesn't wanna turn over I'll replace the fuel filter today and the fuel pump has already been replace it started before running fine no stalling or shutting off so that why I don't think it has anything to do with the lines but I'll try
post #13 of 42 Old 04-18-2017, 01:27 PM Thread Starter
Bluefire35
It's connected exactly how it was before I just don't get how it could be running strong then after replacing the cap and plugs and ignition module it doesn't wanna turn over
post #14 of 42 Old 04-18-2017, 02:11 PM
STJP
STJP's Avatar
That's the first time you've mentioned an ignition module.
JS
STJP is offline
post #15 of 42 Old 04-18-2017, 02:14 PM
WapitiJ
What type of ignition module did you use?
WapitiJ is offline
