Problem #1: When i push in the hazard button nothing happens
Problem #2: When i pull the light knob half way out to activate the parking lights then ONLY the rear side and rear back lights go on. The front signals and front side markers do not come on.
Fact #1: If the car has ignition switch in accessory mode all 6 light (2 front signals, 2 front side markers, 2 rear signals) work as expected
Fact #2: If the parking lights are on AND you push in the hazard button all 8 lights (2 front signals, 2 front side markers, 2 rear signals, 2 rear side markers) come on and do not blink. Turn hazards off and you are back to just the 4 rear lights coming on
Fact #3: I have already replaced the flasher for the hazard and the turn signals. I bought the same flasher (model 552) as i was told there was no difference between the two. When i interchange these flashers i get the same result
Is it possible there is a different flasher for hazards than the turn signal?
Is it possible that the front lights (signal and side) markers are not suppose to come on when you pull the knob half way in the parking light position
