1977 CJ7 Fuel Filler Hose and Vent Hose - JeepForum.com
post #1 of 9 Old 01-29-2009, 08:36 AM Thread Starter
elybarnard
1977 CJ7
I bought an old CJ7 as a project/hobby and I have replaced the gas tank and skid plate ... but I cannot find a place to buy a new fuel filler hose or vent hose. Apparently they changed the setup from from 76 to 77 and then changed it again in 78 so 1977 was an odd year.
I can't be the only person who has had this problem ... is there a work around? Can I replace the fuel filler neck and then use different hoses? Does someone make stock spec hoses for it?
I would appreciate hearing from other 77 CJ7 owners who have replaced the hoses to get some ideas!
Hosed in Florida.
elybarnard is offline
post #2 of 9 Old 01-29-2009, 09:46 AM
BigTDog
Maybe take the old one to your local "auto jerks" and see if you can get one that's close?
BigTDog is offline
post #3 of 9 Old 01-29-2009, 01:35 PM
jeepmaniac
1976 CJ5
4wd Hardware (4WD.com) has the hoses you need, unless someone swapped in a different tank. The molded hose fits best, as it's got a couple of tight bends in the fill hose, and a hole for the vent hose nipple.
jeepmaniac is offline
post #4 of 9 Old 03-25-2009, 08:21 PM
camodad
2010 JK Wrangler
fuel parts
I have a 74 and was able to get mine at O'reilys auto parts. vent hose was about $10.
camodad is offline
post #5 of 9 Old 03-26-2009, 06:56 AM
jfwireless
1976 CJ7
If you have a filler neck with two connections, one for the vent line and one for the fuel fill line, just go buy some marine fuel line of the right diameter and that will work just fine. Marine fuel line has a metal spiral wire wrap so it can make bends without any issues.
Jim
jfwireless is offline
post #6 of 9 Old 03-29-2009, 08:50 PM
RoscoeJ
RoscoeJ is offline
post #7 of 9 Old 07-25-2009, 11:25 PM
ROCKHARDKIM
I Have A 75 Cj5 That Had The Fuel Fill Moved From The Rear Factory Location, To The Side. I Am Now In Need Of A 2-1/2 Inch Diameter Flexible Fuel Line To Reconnect The Tank To The Opening And Be Able To Attach The Overflow Tube To The Side Of This Hose As Well. Any Advise?
ROCKHARDKIM is offline
post #8 of 9 Old 07-26-2009, 04:56 AM
Shasta69
1978 CJ7
Check the post right above yours. They have an area for replacement parts.
BTW - their parts catalogs are sent out free and mine sits next to the camode (only quiet time I get).
Shasta69 is offline
post #9 of 9 Old 07-26-2009, 08:29 AM
incynr8
1974 CJ5
that chains isn't local to me in the NorthEast. If you have a link to an online part number that would be huge, or if you're willing to get those Z shaped filler vent hoses and hook a few of us up.....
incynr8 is offline
source for 1974 'z' shaped fuel filler vent hose? incynr8 Jeep CJ Forum 5 05-11-2009 08:13 AM
fuel filler hose scrappycj5 Jeep CJ Forum 3 05-06-2009 02:13 PM
Fuel filler hose ken78cj5 Jeep CJ Forum 5 04-30-2009 04:16 AM
1977 fuel filler hose... anyone done this? '79 CJ-7 Levi Jeep CJ Forum 20 11-30-2007 12:19 AM
Fuel filler hose 77 CJ5 atom73 Jeep CJ Forum 5 03-20-2007 12:17 PM
