1977 CJ5 vs. 1975 CJ5 - JeepForum.com
post #1 of 7 Old 09-10-2009, 10:08 AM Thread Starter
Fugitt
Looking at a donor CJ for my '77.
Is there any difference between the body of a '75 and '77?
I know the frames are different, boxed in and not boxed in.
Any help would be great.
Fugitt is offline
post #2 of 7 Old 09-10-2009, 10:31 AM
CSP
There's a lot more differences in the frames other than boxed vs. non-boxed. The '75 rails are the same distance apart from front to rear for starters.
The tubs are different. The floor, firewall, and body mounts are quite different.
CSP is offline
post #3 of 7 Old 09-10-2009, 10:32 AM
GraKee99
Rapist Wit
GraKee99's Avatar
You will find a lot more aftermarket support for the 76 and newer CJs than the older ones. That was at least my experience when trying to decide between a 75 and 76 when I started looking at parts.
Brian
WJ, WK, CJ5
GraKee99 is offline
post #4 of 7 Old 09-10-2009, 04:13 PM
26679cj5
i think the 75 is 3 inches shorter than the 77 would be. if you are concerned with after market support, cj5s dont have much no matter which way you go. cj 7's have way more support as far as bolt on parts.
26679cj5 is offline
post #5 of 7 Old 09-10-2009, 04:31 PM
Salt Hay
1978 CJ5
The 75 will have a 30 spline flanged D 44 rear..........possibly the t-15 or t-18 4:1 trans...........if it's just for parts this could help diversify what you already have in the 77.............like others posted bodies are not that close at all.
Salt Hay is offline
post #6 of 7 Old 09-11-2009, 08:30 AM
CSP
No it isn't. The wheelbase change occurred in 1972.
CSP is offline
post #7 of 7 Old 09-11-2009, 11:25 AM
JeepinYahoo
JeepinYahoo's Avatar
1977 CJ5
Like what? Anything for a CJ7 suspension, engine, tranny, axles, etc are all compatible. The only things that aren't the same are the tub, rollbar and rear driveshaft. 76+ CJ5's have just as much aftermarket as their CJ7 counterparts. Furthermore, that wasn't the question asked by the OP.
'77 CJ-5---'63 Scout 80 FOR SALE---'71 Scout 800B---'78 F-250 Camper Special---'75 Econoline 100
JeepinYahoo is offline
1975 cj5 value rajarch Jeep CJ Forum 2 08-08-2012 03:45 PM
1975 CJ5 is too SLOW!! RRenegade Jeep CJ Forum 15 04-24-2009 11:40 AM
tj soa on 1975 cj5 sdhutch Jeep CJ Forum 4 12-12-2007 07:07 PM
1975 cj5 vs 1976 cj5 moose9036 Jeep CJ Forum 4 01-18-2007 10:06 AM
T-5/Dana300 into 1975 CJ only in a jeep cj Jeep CJ Forum 1 12-12-2005 05:48 AM
