1977 CJ5 Steering Upgrade - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > 1977 CJ5 Steering Upgrade
Amsteel Blue Synthetic Winch line Free ShippingWarn and Smittybilt Free Shipping OfferNew items recently added to Oconee Offroad
Unread 03-17-2010, 10:11 AM   #1
mthomp83
2010 JK Wrangler
I have read through a bunch of other threads about converting manual to power steering but couldn't find the answers that I was looking for yet.
The Jeep currently has manual steering. There are other issues which is why I'm replacing all the parts but I want to upgrade to power steering.
I'm going to be replacing the steering column and steering shaft. I will also be upgrading to a reman power steering gear box (it comes w/ pitman arm).
I have purchased the power steering pump w/ reservoir, pressure tubing, and return to reservoir tubing.
I have listed my questions below.
1. How and where do I mount the power steering pump and reservoir?
2. How do I install the power steering pully system?
3. Anything else that I should consider? Am I missing something?
Thanks in advance.
mthomp83 is offline   Reply With Quote
Unread 03-17-2010, 10:31 AM   #2
scottymac62
1977 CJ5
Thanks in advance.
Which engine is this going on?
1) You will need a P/S pump bracket to match your engine first.
2) When I did my P/S conversion, I found a good used pump and pulley on Ebay. All of your pulleys should line up if you buy a pump with a pulley for your engine.
3) Make certain that you buy a steering shaft for power steering, not manual.
You might want to consider upgrading to a reinforced steering box mounting bracket while you're at it.
'77 CJ-5 Renegade 304 / T-150, Dana 20, 30/20 axles, Aussie Locker in the Dana 30, American Racing 15x10 Outlaw II's, 33" Dynapro M/T's" ,Optima Battery, TeamRushed + Summit Racing CDI ignition, FlowKooler water pump, Edelbrock Performer Intake Manifold, Holley 4160 390cfm, Herculiner, Silver Ceramic Coated Hedman Hedders, Flowmaster 40's.
12,000lb Warn Winch, Dirtworx front and rear bumpers.
scottymac62 is offline   Reply With Quote
Unread 03-17-2010, 11:49 AM   #3
mthomp83
2010 JK Wrangler
This is going on a 4.2L 258ci engine.
Is the bracket something that I can buy at an auto parts store like Autozone or Advance Auto Parts or would I have to special order it? Same question for the pulley, I can't seem to find either online at either store.
Also, should the brackets for the power steering gear box match the ones from the manual box or will I have to find a special adapter bracket?
Thanks for the info by the way!
Unread 03-17-2010, 11:55 AM   #4
CSP
Power steering pump brackets are best sourced through a junkyard or a private party selling used parts. They are not available new. Same thing goes for the pulley. AMC cars also used the 4.2 and are relatively abundant in junkyards, in my experience.
CSP is offline   Reply With Quote
Unread 03-17-2010, 11:59 AM   #5
mthomp83
2010 JK Wrangler
Any kind of specific AMC vehicle if I can't find either on a Jeep vehicle?
Also, I'm going out to a huge junk yard on Friday. Should I bring any special tools for removing the pulley or mounting brackets?
Unread 03-17-2010, 12:56 PM   #6
scottymac62
1977 CJ5
Here's the whole kit and kaboodle...............Original Jeep CJ Wrangler Power Steering Pump W/Bracket : eBay Motors (item 110507809013 end time Mar-23-10 09:34:56 PDT)
Unread 03-17-2010, 01:37 PM   #7
mthom5436
1980 CJ5
My dad and I pulled the bracket, pump, box, and hoses out of some sort of AMC station wagon that we found in a junk yard. We went home and everything bolted right up. Easy as pie. Then we discovered ebay. -this was a while ago
mthom5436 is offline   Reply With Quote
