1976 Jeep CJ5 Power Steering Upgrade - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > 1976 Jeep CJ5 Power Steering Upgrade
BlackMagicBrakes 7% Discount, Save today!Poison Spyder from CCOR!HMF Fabrication 50" Light Bar Mounts for CJ/YJ Made I
Unread 11-28-2007, 02:37 PM   #1
Hybrid Jeep
1976 CJ5
Hi all-
I've heard many times that upgrading from manual to power steering on the AMC 258 is fairly easy (1976 Jeep CJ5), but have been unable to find information on what I need to do for the upgrade.
I took a look at the engine last night and saw that there is a place to mount the power steering pump.
Any help would be appreciated!
Hybrid Jeep is offline   Reply With Quote
Unread 11-28-2007, 03:11 PM   #2
Indy
Power steering pump, steering box, pitman arm, hoses and pulley. That should be about it, just bolt on and go. You might not need the pitman arm.
Odds are im typing on a tablet. It takes too much effort to add some punctuation. Im lazy, get over it
Never underestimate the power of stupid.
Indy is offline   Reply With Quote
Unread 11-28-2007, 06:01 PM   #3
John Strenk
John Strenk's Avatar
1976 CJ5
I took all my stuff off an 84 CJ to put on my 76. Watch out for the pulley height. I had to play with mine until it was in line. The water pump flange are different height for different years. I think there was 3 or 4 different Waterpumps from 76 to 86. Depends upon year and accessories.
John Strenk is offline   Reply With Quote
Unread 11-28-2007, 06:33 PM   #4
molsenice
1964 CJ5
I bolted in a 78 cj7 PS setup in my 64 cj5, after welding a crossmember to the frame early in the build - after that, I think it was 3 witch doctors, 2 psycics and a wizzard who snuck in one night, cause it works
no seriously - my situation is way different but with some creativity and lotsa research - anything can get there
I ended up with a tilt colum from a 92 XJ to the 78 stuff and the new 78 hoses fit - sometimes ya get lucky
molsenice is offline   Reply With Quote
Unread 11-29-2007, 12:58 AM   #5
T18A
1977 CJ5
T18A is offline   Reply With Quote
