1976 CJ7 Dash Lights - JeepForum.com
post #1 of 4 Old 07-21-2007, 08:21 AM Thread Starter
esteve999
1976 CJ7
I cannot seem to find a thread with the same problem.
1976 CJ7
There are dash lights in 4 places, Speedometer, steering column (it's an automatic), battery power, oil.
-Steering column and oil gauge work
-Signals in speedo work
-General lighting of speedo does not work
-Battery power does not work
Seems like it could be bulbs or ground.
esteve999 is offline
post #2 of 4 Old 07-21-2007, 10:13 AM
jeepwhore
I think you answered your own question. Check the ground. If its good, replace the bulbs. If your gas and temp. gauges work then the speedo housing is grounded properly. in that case, the speedometer lights probably just need replacing. I don't recall how the volt gauge grounds so check both the ground and bulbs on that one.
jeepwhore is offline
post #3 of 4 Old 07-21-2007, 01:00 PM
burchdog32
1976 CJ7
I just had a similar problem (see thread for more detail).. May not be the same thing, but my problem was fixed by buying a new light switch dimmer. It cost $15 at Advance auto parts.
http://www.jeepforum.com/forum/f8/no-dash-lights-no-fuel-temp-guage-434432/
Best of luck!!
burchdog32 is offline
post #4 of 4 Old 07-21-2007, 05:38 PM Thread Starter
esteve999
1976 CJ7
Thank you for your responses.
It turned out to be bad bulbs and, believe it or not, one of the socket was actually missing a bulb.
Dash lights.! MHSJEEPKID2012 Jeep CJ Forum 3 10-15-2009 03:07 PM
dash lights and head lights "pulse" slightly CrazyHorse6 Jeep CJ Forum 17 02-16-2009 01:20 PM
Dash lights out!! newjeepguycj5 Jeep CJ Forum 9 03-09-2006 08:38 AM
no brake lights and no dash lights boydog40 Jeep CJ Forum 6 03-01-2006 06:49 PM
Where's my dash lights? Dtray332 Jeep CJ Forum 3 11-10-2002 08:22 AM
