1976 cj7 allergic to water - JeepForum.com
post #1 of 2 Old 08-11-2002, 04:04 PM Thread Starter
JeepFarmer
I am running a 304 amc with stock ignition. Whenever the jeep so much as smells water (driving through mud puddle) it sputters and sometimes dies and leaves you stranded for a half hour or so. We moved the gold box up on the top of the fender and siliconed the harness to keep it away from moisture, but now it misses terribly and the water situation is still just as bad. Any suggestions?
JeepFarmer is offline
post #2 of 2 Old 08-11-2002, 06:23 PM
cjryder
Jeepfarmer, had a problem like yours before. Could be carbon tracing on the inside of the distributor cap. High humidity will do it too. The fix might be as simple as a new distributor cap, as yours may have invisible hairline cracks. Its cheap and worth the try anyway.
cjryder is offline
1976 Cj-5 GraKee99 Jeep CJ Forum 1 08-15-2009 05:34 PM
1976 fuse Q's otterred Jeep CJ Forum 6 05-06-2009 05:03 AM
1976 304 timing meatloaf Jeep CJ Forum 5 10-11-2008 06:22 PM
1976 CJ7 - Water Leaking in esteve999 Jeep CJ Forum 18 09-15-2007 07:58 PM
1976 CJ7 Soft Top esteve999 Jeep CJ Forum 5 11-02-2006 11:02 AM
