1976 cj-5 brakes - JeepForum.com
post #1 of 3 Old 07-29-2011, 07:57 AM Thread Starter
skinhinajeep
1979 CJ7
1976 cj-5 brakes
My brake pedal goes all the way to the floor, I noticed that one side of the master cylinder is losing fluid but i cant find the leak, i used to be able to put more fluid in and pump the pedal and it would be ok, now the pedal still goes to the floor, any suggestions?
Thanks,
TC
skinhinajeep is offline
post #2 of 3 Old 07-29-2011, 08:33 AM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
It sounds like there is air in the system. Try bleeding it and seeing if that improves the pedal. The problem is that if it's leaking enough to let in air, then you might not be able to bleed it successfully.
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline
post #3 of 3 Old 07-29-2011, 08:48 AM
Dudman5703
If there is a leak, you will have to find it if you want your pedal to return to normal and stay that way.
I usually get stuck helping my friends with brakes and recently had to redo everything except the brake booster.
Just look underneath for a wet area of brake line or if your lucky itll get the frame wet too and be easy to see.
Also check the drums to see if its leaking out the cylinder in there.
Then replace whatevers leaking.
If your master cylinder went dry in one of the areas you'll have to bench bleed the master cylinder to get the air out of that, then bleed the lines after that. You can't get the air out of the master cylinder by regular bleeding.
Squishy pedal = air. And if its leaking, thats where the air came from!
°llllll° Money well wasted
Dudman5703 is offline
Frame on a 1976 CJ5 lmcgehee Jeep CJ Forum 1 11-11-2010 08:12 AM
my 1976 cj5 scrappycj5 Jeep CJ Forum 5 09-08-2010 09:13 AM
1976 cj7 heat hold24 Jeep CJ Forum 15 10-29-2009 02:26 PM
1976 Cj-5 GraKee99 Jeep CJ Forum 1 08-15-2009 04:34 PM
1976 CJ7 4 Wheel Drum Brakes Proportioning Valve Bromius76 Jeep CJ Forum 2 03-26-2007 08:02 AM
