1975 CJ5 is too SLOW!! - JeepForum.com
post #1 of 16 Old 03-03-2009, 05:43 PM Thread Starter
RRenegade
So I have been working on a 75' CJ5 that my uncle gave me for awhile now. It ran as he drove it into the shop and parked it. I have done a lot of rust killing and body work on it mainly. I painted it all and everything. I got it to a stage to put seats back in it and tuned the engine up (232 I6). I took off down the road and found that in 3rd gear(last) I would top out around 45mph with 33" tires.
I'm not sure what transmission or transfer case I have. I just kind of went to town working on this jeep. haha.
EDIT: I think I have the T-14 trans.
It is planned to be ran on the beach and around town mainly, but I need to be able to hit 55 for about 10 miles to make it to the beach.
I have a set of 35's that would probably fit, but I'm not sure how good the axles will handle them.
Can someone point me in the right direction with how to make this thing hit 55mph without blowing it up?
Thanks!
93 Red Wrangler Renegade
RRenegade is offline
post #2 of 16 Old 03-03-2009, 05:48 PM
curbcrawler
1946 CJ2A
not sure what your axle gearing is but you could change them. That would allow you to go faster but would deplete your low end a bit.
Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote. - Benjamin Franklin
-commit2013-
curbcrawler is offline
post #3 of 16 Old 03-03-2009, 06:04 PM
khamill
1972 CJ5
As I recall, the only axle ratios available were 3.73 or the optional 4.11. You really need to find out what ratio you have as either of these should be fine at 55mph.
I'll click on anything. Just post it.
72 CJ5
56 Willys P.U.
48CJ2A
khamill is offline
post #4 of 16 Old 03-03-2009, 07:28 PM
HackFabrication
HackFabrication's Avatar
1976 CJ5
Shift the transfer case out of low.....
"In the end...It's all Hack."
HackFabrication is offline
post #5 of 16 Old 03-03-2009, 07:31 PM
gimmesomerocks
good call hack
gimmesomerocks is offline
post #6 of 16 Old 03-03-2009, 09:38 PM Thread Starter
RRenegade
I'll be happy if this is the case!! haha I'll give it a try.
Thanks
post #7 of 16 Old 03-03-2009, 10:04 PM
sweetguardian00
1946 CJ2A
NITROUS! lol, NO NO NO, well, the 232 doesnt have as much nut as a 258, could always do a swap....... heck, Ford 302 while your at it
1946 CJ-2A 225/T90/D18
1966 CJ-5 231/T86/D18
1986 CJ-7 258/TF999/D300
1984 C-10 6.2/SM465
Yeah it's a Diesel
sweetguardian00 is offline
post #8 of 16 Old 03-03-2009, 11:03 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
A 232 will pull the rig just fine. I'm expecting hack has hit the nail on the head.
If it does indeed have aT14, I would be hesitant to flog it much. They do not hold up well.
jeepdaddy2000 is online now
post #9 of 16 Old 03-03-2009, 11:25 PM
ragsdale
1975 CJ5
Your speedo could be off also.. Mine says 55-60 when im going 70, If its not your t-case, have someone pace you
Don't eat vegetables from a garden that was formerly a cemetery.
ragsdale is offline
post #10 of 16 Old 03-04-2009, 04:19 AM
Exposed
Exposed's Avatar
1981 CJ5
Hack Had it Right....
When I test drove my 81 CJ5, it had the same problem.. I only drove about a mile or so in a sub division. When it got up to about 45, it was pretty much there... Big tires, 258 and I wrote it off needing some work.. Got it home and let the wife drive and same results.. So starting messing with the 4 wheel drive and realized it was in low range... duh.... Anyway, shifted to hi and everything was ok on going faster than wanted to.....
Exposed is offline
post #11 of 16 Old 03-04-2009, 04:49 AM
wendell
1987 YJ Wrangler
It's a jeep not a mustang ha ha. I had a 75 CJ-5 with the 258 and 3 speed with 31x10.50's, it was plenty of fast enough. It would do 60-65 easy. You could swap in a 258 and put on a holley 4 barrel, offy intake, cam and header, add an HEI distributer and MSD. That will bump up the power, actually, they sell those parts fpr the 232 as well. That seems a might slow unless it has 4:88 gears are something.
1987 wrangler, 258 I-6, 5-speed.
2007 liberty sport 4X4, automatic
2009 ford ranger 4x4 FX4 OFF/ROAD, 5-speed
wendell is offline
post #12 of 16 Old 03-04-2009, 06:32 AM
ET48
Put a bigger motor in it
ET48
1986 CJ-7 LAREDO, 4.2L, 5 speed, 3.31 Gears, D30, D44, 2.5" ProComp lift, 3" BL, 33" TSLs.
1998 TJ SAHARA, 4.0L, 5 speed, 4.11 Gears, D30 (Aussie Locked), Ford 8.8, 4.5" Custom LA, XRC8, AA SYE, TW DS, ZJ tie-rod, Full-Traction front adj. track bar, 35" KM1s.
ET48 is offline
post #13 of 16 Old 03-04-2009, 06:42 AM
74CJMatlock
1974 CJ5
I'd agree with Hack. Not to belittle, but are you familiar with the shift pattern for the Dana 20? 2wd High should be just forward of neutral (in the middle) of your transfer case range. All the way forward is 4wd high. Put the transfer case lever in the middle until you find neutral (transmission in gear, engine running, and Jeep doesn't move). Then move it forward slowly until it engages. That's 2H. If you're one back from N, you could have it in 2L, which isn't an "official" setting on the D20, but you can find it on some transfer cases.
If you're sure you have it in 2H and are still getting these problems, then I'm out of suggestions. That isn't a huge engine, but you should be able to get better than 45 MPH with 33's. I would think that your stock ratio is 3.73. I've never heard of anything but 3.73's on the 72-75 CJ-5's, but I won't discount the possibility that 4.11's were offered as an option. Is there a chance that a PO messed with the gearing, either by putting higher (numerically lower) gears in it such that you're out of your power band, or lower (numerically higher) gears in it such that you're maxing out at 45mph? A tag on the diff will tell you what gears are stock (and if someone was really thinking, they may have changed it or altered it when replacing gears). If you can't find that, or don't believe it, you can jack the Jeep up, secure it, and by marking the tire and the driveshaft, you can estimate the gear ratio by counting the number of times the driveshaft turns per revolution of the tire.
1974 CJ-5
locked front and rear
74CJMatlock is offline
post #14 of 16 Old 04-24-2009, 06:32 AM
gimmesomerocks
Must have been in LOW 4.......
post #15 of 16 Old 04-24-2009, 07:45 AM
Nickmil
I also vote the possibility of being in 4 low.
By the way, the stock gearing options in that year were 3.73-1 and 4.27-1, either of which you can run down the hiway just fine, especially with 33" tires. Heck, I've got 5.38's and run down the hiway at 55-60 with no problem with 33" tires and a buick V-6
'59 CJ-5, '59 CJ-6, '68 CJ-5, Bone stock '57 CJ-5, a couple of XJ Cherokees
Nickmil is offline
1975 cj5 value rajarch Jeep CJ Forum 2 08-08-2012 03:45 PM
slow slow slow cj2a willys build sega2010 Jeep CJ Forum 13 11-15-2011 08:59 PM
1977 CJ5 vs. 1975 CJ5 Fugitt Jeep CJ Forum 6 09-11-2009 11:25 AM
tj soa on 1975 cj5 sdhutch Jeep CJ Forum 4 12-12-2007 07:07 PM
1975 cj 5 lift mrowe26 Jeep CJ Forum 14 04-06-2006 05:45 PM
