1975 CJ-5 not getting fuel - JeepForum.com
post #1 of 5 Old 01-17-2010, 02:29 PM Thread Starter
jmpunited9
1974 CJ5
Hey guys. My buddy drove his jeep about 4 weeks ago and it was running like a champ (and has been), but after garaging it for the past month it is now no longer getting fuel. Here is what we have tested:
Previous to driving it 3 months ago we tested the pump and it was puming out fuel fine. It was filling a clear coke bottle in seconds (16 oz). My question is....do fuel pumps break over time or do they just all of a sudden stop working like this during storage. Is there anything else it can be? I was thinking that there may be a crack in the fuel line somewhere, but will that small amount of air getting in the fuel lines prevent the pump from pumping out fuel at all? We currently have the line disconnected BEFORE the fuel filter, so i am 100% sure its not the filter. The end of the line is sitting in a clear coke bottle and not a single solitary drop of fuel is coming out. And yes....the gas tank is full.
Is there anything else I should be checking before jumping to the conclusion that the fuel pump just magically broke while sitting still in a garage for 4 weeks? Is there maintenance that can be done to fuel pumps? can they clog?
jmpunited9 is offline
post #2 of 5 Old 01-17-2010, 03:09 PM
retrofit9
1979 CJ7
Yea the fuel pumps go bad just like you are saying. Mine did the same thing a few years ago and the fuel pump was'nt that old either. I let it sit over a winter and the diaphram went bad. I thought it had to be somthing else to since the pump was only a few years old. Changed it and it fired right up. Easy fix at least lol.
retrofit9 is offline
post #3 of 5 Old 01-17-2010, 03:20 PM Thread Starter
jmpunited9
1974 CJ5
was the fuel pump replacement difficult/labor intensive? I am yet to have to do one on a CJ
post #4 of 5 Old 01-17-2010, 04:15 PM
Aduffy32
I used my electric pump to drain my tank. I must have overworked it because it just suddenly stopped working.
jeepaholic
Aduffy32 is offline
post #5 of 5 Old 01-17-2010, 04:28 PM
retrofit9
1979 CJ7
If its a mechanical fuel pump on a 258 I-6 its very easy. There is a fuel line in and a fuel line out and two bolts that hold it to the block. You'll need a new gasket with the new pump and some non hardening permatex. Scrape the old gasket matieral off the block after you remove the old pump. If I remember, the bolts holding the pump on the block are 7/16, so you'll need a 1/2" wrench for those and a 1/2" line wrench for the gas line to the carb. Brian.
1975 cj5 value rajarch Jeep CJ Forum 2 08-08-2012 03:45 PM
tj soa on 1975 cj5 sdhutch Jeep CJ Forum 4 12-12-2007 07:07 PM
1975 cj5 vs 1976 cj5 moose9036 Jeep CJ Forum 4 01-18-2007 10:06 AM
tow a 1975 CJ5 using a dolly, will it be ok? dirkdiggler106 Jeep CJ Forum 9 07-12-2006 02:30 PM
1975 Cj5w? OlllllllO Jeep1 Jeep CJ Forum 3 05-22-2005 07:14 AM
