1974 CJ8 scrambler--tell me what you know - JeepForum.com
post #1 of 23 Old 11-13-2008, 08:26 PM Thread Starter
underpowered
Bouncin' on a Budget
underpowered's Avatar
just looking for general info on it. my buddy in looking at trading his 95 YJ for one.
i know it has the 4.2 6 popper in it, backed by a 4 speed. what tranny? what T-case? what axles and gears does it most likely have?
it is sitting on some Q78-15 buckshots, how much lift would it need to clear them? It looks like maybe 4" lift or so, but i am not familiar with teh CJ's. just looking for anything he should watch out for before buying it.
1998 ZJ-- lowered a touch
2005 GMC 2500HD 496 C.I.
Fat Amy-1989 K5 blazer. Linked, lifted, 38.5's on won tons. Big Girls can play in the woods too.
underpowered is offline
post #2 of 23 Old 11-13-2008, 08:30 PM
jeepskate
I'm assuming you meant 1984. Trans would be a T-176 (decent) or T-4 (not so durable)...you can find ID info at www.jeeptech.com in the transmission section. Dana 300 t-case is it for 80-86, axles are Dana 30 front, AMC 20 rear...use the axle info at the same site to decode what your gear ratio should be (assuming they weren't changed to go with the larger tires). Typical gearing is 2.73 with 3.31's as an option w/the towing package. 4" lift would be about right for clearing those tires.
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
jeepskate is offline
post #3 of 23 Old 11-13-2008, 08:33 PM
bjf498
bjf498's Avatar
1983 CJ7
Where is the owner of the cj8?....... so I can punch him in the crotch for trading a yj for a scrambler.
Small, fine shavings are ok, large chunks are bad, huge chunks with part number stamped on them are real bad.
bjf498 is offline
post #4 of 23 Old 11-13-2008, 08:37 PM Thread Starter
underpowered
owner said it was a 1974.....i dunno.
teh way it drove, teh gears seem to high for it. i doubt they have been changed.
post #5 of 23 Old 11-13-2008, 08:40 PM
bjf498
bjf498's Avatar
1983 CJ7
2.73's are enough to make that poor 258 bog with big tires.
bjf498 is offline
post #6 of 23 Old 11-13-2008, 08:41 PM
jeepskate
Well Scramblers were only made from 1981-1986, so...
post #7 of 23 Old 11-13-2008, 08:50 PM Thread Starter
underpowered
lol. i noticed that. must be an 84 then.
and after reading up, it might be teh 232 not the 258. the owner knows as much about it as i do, which is not much.
it has a hard time taking off. if he gets it, regear is definitely in order for it.
post #8 of 23 Old 11-13-2008, 08:52 PM
CjinPA
CjinPA's Avatar
All Scrambles left the factory with either the 258 motor or the 4 cylinder motor.
84 CJ7 Northstar V8
91 YJ Renegade.
I've been in this rut plenty long enough, I know what to expect. Weather my day is hell, or weather it goes well is kind of up to me I guess.
CjinPA is offline
post #9 of 23 Old 11-13-2008, 09:34 PM
CJman77
1977 CJ7
Really? None came with a factory v8? What a shame!
CJman77 is offline
post #10 of 23 Old 11-13-2008, 09:43 PM
jeepskate
Nope. '80 or '81 was the last year the 304 V8 was offered, Scramblers didn't get them.
No, it would not be a 232.
post #11 of 23 Old 11-13-2008, 10:32 PM Thread Starter
underpowered
thanks for the help fella's. i will pass the info along to my budddy.
post #12 of 23 Old 11-14-2008, 08:46 AM
SuB8HaVeN
What size tires did it have? I have the 258 I6 with 3.31 gears and 31" tires and it's no hot rod, but it's manageable. I had 33" BFG ATs on it at one time with the same gears and that was pushing it as far as driveability goes, especially when I was trying to haul my boat.
1986 Jeep CJ7 4.2L I6 T176 (restoration in progress)
1961 Willys 4x4 Wagon L-226 I6 T90 (restoration also in progress)
SuB8HaVeN is offline
post #13 of 23 Old 11-14-2008, 10:54 PM
wm69
I don't think anyone has ever confirmed an 86.
That's my "add something useless to the thread" post.
wm69 is offline
post #14 of 23 Old 11-15-2008, 10:01 AM
jeepskate
I know at least two people who had/have 86's...there were only a little over 100 made.
post #15 of 23 Old 11-15-2008, 10:08 AM
Cherokeester
Cherokeester's Avatar
1980 CJ7
Make sure it is a scrambler and not a CJ-6. It sounds like you need a lot more info.
1980 CJ-7 with a AMC 401, RE 4.5" Lift, 4-1 Dana 300, Holley TBI Projection, 35" Goodyear MTR's
2010 Rubicon Unlimited
1997 TJ with various enhancements
Cherokeester is offline
SCRAMBLER: Should I buy this MINT Scrambler QUICK RESPONSE NEEDED! jatepper Jeep CJ Forum 42 07-06-2009 11:16 AM
1974 CJ5 Value goingtopless Jeep CJ Forum 16 01-01-2008 08:07 AM
1974 J30 omanalansanjr Jeep CJ Forum 0 10-02-2007 02:48 PM
SCRAMBLER PEOPE - HELP PLEASE ->A Scrambler and Towing SomerJeep Jeep CJ Forum 6 06-09-2006 06:49 PM
1974 cj 5 cherokeenation Jeep CJ Forum 6 01-15-2003 08:50 PM
