1974 CJ5 Newbie - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > 1974 CJ5 Newbie
Spartan Locker Promo Running now @ ROCKRIDGE 4WD plus FREEANOTHER Rockridge4wd Creation!! Spare Tire Carrier Delete Gear Installs at CCOR Special
Unread 10-23-2014, 03:53 AM   #1
cjjp
1974 CJ5
1974 CJ5 Newbie
Good Morning Jeep Fanatics -
The name is JP, and my dad just gifted me with a 1974 CJ5 that he bought off of ebay last year.
Here are some disclaimers about me:
Totally new to tinkering and modifications. I have 2 little boys who want to start turning wrenches and learning. I too have ambitions of doing the same. I grew up watching my father work on vehicles, but, sadly, I never took much interest, until now that is...
So, like any person who has interest and true grit, I pulled the beast into the garage tonight, lifted the hood and started looking for common wear and tear issues.
1st Issue spotted
When we drove the jeep today, the temperature gauge went to HOT pretty quickly. But, the fuel gauge was also acting funny/not accurate. We decided to not push it so we let it cool down. However, after letting it cool down for about 2 hours, we started it back up. The radiator and engine were cool to the touch, yet the thermostat was still showing hot??? When I turn the keys over to battery, the gauges aren't working, it seems. When I start it up the gauge goes to H - immediately.
OVERHEATING? or BAD GAUGE?
Hoses are beat to hell and showing their age. Specifically the hose from the radiator to the engine block where the thermostat is housed. I pulled that stubborn SOB off tonight and drained the coolant. I also thought that perhaps the thermostat may have been sticking? I have heard that term before. Not sure what that means other than by "sticking" it can fool the gauge to thinking its Hot? <---- HELP HERE
I have the hoses and thermostat pulled off the radiator and engine. I was planning on taking them to AutoZone tomorrow to see if they could help me source the parts at their store. When I went there last night and gave them my year and model, there were 3 options I believe in engine size, none of which are mine. My engine is, as far as I can tell, not one of the listed engines. The desk assistant said "Oh, well, you are going to need to know what engine you have so that we can get you the right part, or you will need to pull the thermostat"
ISSUE: What if the the thermostat that is in there is wrong to begin with? Shouldn't I know what engine I have to be certain?
Herein lies my other issue:
I dont know what type of engine I have. The last guy that worked on it stated that it was a 307. I can tell you it sounds like a dragster when it starts up - LOUD/STRONG/AGGRESSIVE
I imagine that an engine swap occurred when in the hands of the previous owner, to which I have no contact.
ENGINE QUESTION:
How the heck do I identify what engine I have, so that I can start getting the correct parts?
Thanks so much. I look forward to chatting with you all and sharing my progress and I bury myself inside the Jeep lifestyle.
-JP-
cjjp is online now   Reply With Quote Quick reply to this message
Unread 10-23-2014, 05:08 AM   #2
tcijoe
Junior Member
1974 CJ5
I would suggest posting pictures of you engine area.
74 CJ 5, 258, t-18, Dana 20 t/c, Ramsey pto winch, 33 x 12.50 maxis mudders, duplicolor bed armour interior, low back seats.
tcijoe is offline   Reply With Quote Quick reply to this message
Unread 10-23-2014, 08:33 AM   #3
CSP
A 307 would be a Chevrolet V8, but the prior owner could have been mistaken and it's a 304, which is an engine that would have been available in a '74.
Is the distributor at the front of the engine or back by the firewall?
Pictures would help.
www.jeeptech.com has all kinds of identifying information.
CSP is online now   Reply With Quote Quick reply to this message
Unread Yesterday, 08:47 PM   #4
cjjp
1974 CJ5
Here is the engine pic
ttp://i58.tinypic.com/hrwz0l.jpg
Unread Yesterday, 08:48 PM   #5
cjjp
1974 CJ5
[QUOTE=cjjp;26347106]Here is the engine pic
Unread Yesterday, 09:35 PM   #6
CSP
That's an AMC V8 and most likely a 304. Look on the side of the block behind the motor mounts. The displacement is cast in big numbers into the block.
If the radiator and block were cool to the touch, but the gauge read hot you either have a bad gauge or a bad sending unit.
Google "CJ gauge diagnostics" to find some great troubleshooting by John Strenk, one of the contributors on this site.
BTW, your power brakes are an aftermarket setup. That master cylinder is a Corvette master.
Unread Yesterday, 10:19 PM   #7
lucdog
lucdog's Avatar
1980 CJ5
Originally Posted by CSP
That's an AMC V8 and most likely a 304. Look on the side of the block behind the motor mounts. The displacement is cast in big numbers into the block. If the radiator and block were cool to the touch, but the gauge read hot you either have a bad gauge or a bad sending unit. Google "CJ gauge diagnostics" to find some great troubleshooting by John Strenk, one of the contributors on this site. BTW, your power brakes are an aftermarket setup. That master cylinder is a Corvette master.
This^^^
Also looks like a points distributor.
There appears to be the small metal "trap door" that is just in view on the back left side of the cap, and the clamp on the housing under where the hold down screw is for the cap,
1957 WILLYS pickup, needs work.
1973 J 4000,
1978 CJ7 DD.
1979 CJ7 360, TH400/Quadratrac trail Jeep.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7 pretty weekend and sometimes to work Driver in the summer, My first rebuild, if the Q-trac and 5 are broke, this one is the one to take. its just as capable as the other 2, except nice paint.
1984 Grand Wagoneer, 1 ton axles, great 360/727, and a big a$& tree fell on it .
1989 YJ the CJ to YJ conversion.
2005 TJ Rubicon.
2011 Grand Cherokee Laredo 4x4, Mrs. LUCDOG's DD.
Lots of parts not for sale, i'm a hoarder.
lucdog is online now   Reply With Quote Quick reply to this message
Unread Yesterday, 10:31 PM   #8
CSP
Delco points distributor would have been stock in a '74.
cj5 , engine , overheat , thermostat
