1974 CJ5 Leaf spring question - JeepForum.com
post #1 of 4 Old 11-11-2002, 12:18 AM Thread Starter
jrejle
I have a 1974 CJ5 and I was putting on new shocks when I happen to notice that my left (drivers side) rear leaf spring only has 5 leafs and my right (passengers side) has 9. I looked in the 4 wheel drive hardware manual and both sets of springs were options for 1972-75 Jeep CJ5's. Is it possible that it came this way from the factory? I have only had the Jeep for about a year and it is pretty much stock. I put a level on the bumper and it is level.
Jim
jrejle is offline
post #2 of 4 Old 11-11-2002, 05:31 AM
rustyCJ
look at how many leafs the front have, wether they are the HD spring packs or not and also look at the spring bushings to see if they look newer then the rest. i would assume that somewhere down the line that a rear leaf was busted and instead of replacing both they replaced one.
"character is doing the right thing even if nobody is looking"
rustyCJ is offline
post #3 of 4 Old 11-11-2002, 08:56 AM Thread Starter
jrejle
I just replaced the bushings. They were all shot. All seemed to have about the same amount of wear. The front has 7 springs per side. Im guessing that it had to be replaced at some point.
Jim
jrejle is offline
post #4 of 4 Old 11-11-2002, 09:51 PM
rustyCJ
if you have 7 leaf packs in the front then you should have 9 leaf packs in the rear. if the 5 leaf pack isnt a replacement pack then it may have just had some of the leafs removed. it didnt come from the factory this way. if its not really a problem dont worry bout it, if it bugs you, replace both rear springs.
rustyCJ is offline
SOA - YJ leaf spring question? Area.3.Fiftyone Jeep CJ Forum 2 11-30-2009 08:23 AM
Leaf Spring Question? CoryA Jeep CJ Forum 6 10-19-2009 09:15 AM
Another CJ7 leaf-spring question jeromehdmc Jeep CJ Forum 9 12-17-2006 01:13 PM
Leaf Spring Question. Curly Jeep CJ Forum 1 05-21-2003 02:08 PM
Leaf Spring question antman Jeep CJ Forum 3 09-21-2002 04:53 PM
