1974 CJ5 Brake Kits for drum brakes - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > 1974 CJ5 Brake Kits for drum brakes
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffstuff Axle Simple Swap Kit!TJ BDS 2" suspension lift!! FINALLY a GREAT 2" l
Unread 03-26-2015, 10:50 AM   #1
Scuter83
1974 CJ5
So I have a 1974 CJ5 with front and rear drums, manual brake master cylinder (no booster). I keep looking to find replacement brake kits so I can order everything at once and replace it all, but struggle to find stuff for my application. I can find parts, or things that sound right, but aren't listed for a '74, or my axles (Dana 30F, 44R).
Does anybody know where to order complete kits instead of piecing together parts?
Thanks,
Scott
Scuter83 is offline   Reply With Quote Quick reply to this message
Unread 03-26-2015, 11:05 AM   #2
CSP
You're not going to find a kit that replaces everything because not all parts need to be replaced every time someone needs to do a brake job. There's not enough demand for anyone to put together a "kit" that's all inclusive.
Any auto parts store will have, or can get, just about any brake part you need. If there's something you can't find specifically ask about it here and someone can help you get what's missing.
CSP is offline   Reply With Quote Quick reply to this message
Unread 03-26-2015, 06:37 PM   #3
AeroMoto73
1973 CJ5
Try http://www.the-jeep-guy.com/
I got a front disc brake kit from him and I think he does drums as well. I'll sell the whole front drum brake setup that I took off my 73 if you want it for cheap. It's just sitting under my work bench right now.
AeroMoto73 is offline   Reply With Quote Quick reply to this message
