1974 cj-5 clutch linkage problem, help! - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > 1974 cj-5 clutch linkage problem, help!
WIN a Rough Country Forged Track Bar - ExtremeTerrain!FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6
Unread 12-01-2009, 09:56 AM   #1
jmpunited9
1974 CJ5
Hey guys. Iím having a problem with my clutch linkage. I am not 100% sure the name of the part, but I believe it is the release rod/adjuster. At the end of the linkage, there is an adjustable rod with a metal ball at the end of it. Itís the last part of the clutch linkage before it hits that plate that actually goes into the clutch. Well here is my problem. No matter how much I adjust that rod (expand it out to make it longer, to keep more pressure against that plate) it always seems to pop out at some point while on the trail. I am tired of having to get under there and pop it back into place over and over again each day I drive it on the trails. To make matters worse, even though it is a little bit better now that I have tightened it up (expanded it to make it longer and keep more pressure on that plate), my clutch now doesnít engage unless itís basically up at my neck. The more I expand that adjuster to keep more pressure on the rod to that plate, the later the clutch is going to catch. I have found new clutch replacement parts, but am confused how that will fix my problem unless my problem is that the ball at the end of the rod/adjuster is just so worn that it doesnít stay properly. Click on this link and it is the part labeled ďrelease rod and adjuster.Ē http://www.jeepfan.com/tech/clutch-l...ch_linkage.gif The only difference on my part, is that at the end of the adjuster it is more like a round metal ball. Not a washer looking thing with a hole in it like that one appears to be in the crappy picture. Are there any remedies to making this piece stay better? Also, the release spring IS still attached to the release lever (plate) and correctly attached to my frame for extra compression. I just canít keep this damn thing on. If my description isnít good enough, I can try to take pictures later of my actual piece. I am sure most of you know what I am talking about though.
jmpunited9 is offline   Reply With Quote Quick reply to this message
Unread 12-01-2009, 10:19 AM   #2
Mike1084
1979 CJ7
How much play do you have in your clutch pedal? Do you still have the jam nut on the threaded rod?
Mike1084 is offline   Reply With Quote Quick reply to this message
Unread 12-01-2009, 10:24 AM   #3
CSP
Since this is a '74 with an open c-channel frame it isn't a function of the adjustment being correct. It's a matter of frame twist. My '75 used to do this on a regular basis before I went to a hydraulic clutch.
The distance between the frame and engine decreases when you flex one way and you almost can't disengage the clutch. Flex it the other way and the distance increases, leading to the adjuster rod popping out of the indentation in the clutch fork.
You may want to check the condition of your motor mounts as a bad one will make this happen more often. I found that a stiff spring mounted to the clutch fork and bellcrank almost eliminated this popout condition also, but it would still happen on occasion.
CSP is offline   Reply With Quote Quick reply to this message
Unread 12-01-2009, 10:35 AM   #4
CJ258
1974 CJ5
That's the same twisting that binds up and makes shifting impossible sometimes 'til you kill the engine to shift and restart with the clutch in. There's a write up somewhere about using heim links to correct that linkage problem.
CJ258 is offline   Reply With Quote Quick reply to this message
Unread 12-01-2009, 10:56 AM   #5
CSP
Heim joints won't correct the problem of the frame twisting though. Once the distance between the bellcrank and clutch forks reaches a certain point it won't matter what the end of the linkage is made with. It's going to pop out.
The spring was the only thing that minimized the part popping out and going hydro solved it completely.
Unread 12-01-2009, 11:05 AM   #6
jmpunited9
1974 CJ5
That picture you posted is correct. The first picture is what attaches to the linkage working its way up to the pedal and the second picture fits on the other end of it and presses against that plate. I do believe that it is EXACTLY what you are talking about when it comes to frame flex though. I can feel the frame flexing a little and regardless of how much pressure I create by expanding it outward a little by unthreading it some, it still pops out. It is super freaking frustrating having to go under there and pop it back in when everything is hot. The only way I can completely solve the issue is if I ride with my foot actually pushing a decent amount of pressure on the clutch pedal itself without disengaging the clutch. This seems to add enough pressure to stop it from happening. What is most frustrating of all, though, is that unless I have those pieces expanded enough to where the pressure is pretty darn great, it comes out every 1 or 2 minutes. So im driving around with my knee basically in my chest because the clutch doest engage/disengage until its at its highest point now. I tried to find a nice medium, but it just falls out unless I have it very tightly expanded under there. I wish the indentation of that plate was a little deeper. I feel as if it would happen less if that ball could sink in that hole more.
Unread 12-01-2009, 11:19 AM   #7
John Strenk
John Strenk's Avatar
1976 CJ5
Give it time, It will rust through and the ball will be driven right through it. Ask how I know.
I've had good luck with the heim joint set up but the only way to eliminate it is to put in an hydraulic system.
Not easy on a 74 but not impossible.
John Strenk is offline   Reply With Quote Quick reply to this message
Unread 12-01-2009, 11:25 AM   #8
CSP
Try a stiff spring between the clutch fork and the arm of the bellcrank that the release rod attaches to. It makes a world of difference. I used to keep my foot on the pedal also prior to installing a spring.
Unread 12-01-2009, 11:27 AM   #9
cj5752
1975 CJ5
Do you have a spring between thew bellcrank and cluck fork to hold tension on the parts? If not adding one will help or eleminate your problem.
cj5752 is offline   Reply With Quote Quick reply to this message
Unread 12-01-2009, 11:37 AM   #10
jmpunited9
1974 CJ5
sorry for my novice usage of terms, but the only spring i have on there right now is the spring that connects that plate going into my clutch, to a small hole in the frame. Is that what you mean? Aside from that, the pressure between those two parts seems really good. But ONLY when I expand that piece to make it that way. Which, once again, makes my clutch catch so freakin high its rediculous. My clutch pedal basically slaps the bottom of my balls by the time it engages/disengages now. There has to be some sort of redneck engineering to keep this ball pressed against that plate during frame flex...
Unread 12-01-2009, 12:06 PM   #11
jmpunited9
1974 CJ5
What if I welded 4 small plates around the perimeter of that place. Just about a 1/4" all around the outside of the hole and just about 1" off the plate going toward the front of the jeep. They would act as walls basically, so when the ball pops out it would hit the wall and find its way back and re-seat itself. It seems like there would be enough room for everything to move the way it has to naturally and not hit the walls. Bad idea? easier suggestion? I can take a pictures of my actual linkage later to see if you guys think the wear on the ball at the end has anything to do with it
Unread 12-01-2009, 12:18 PM   #12
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
There is supposed to be a spring from the arm going into the clutch that goes forward and hooks on the bell crank. This spring runs beside the adjuster and simply holds it in place. A chunk of wire would also work, but you woulod have to change the wire every time you adjusted the clutch.
Your clutch pedal is supposed to have an inch or so of slop up top so this spring is needed to hold the adjuster in place.
Mine also falls out just like yours without this spring.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote Quick reply to this message
Unread 12-01-2009, 12:26 PM   #13
jmpunited9
1974 CJ5
hmmm. I'll check and take pictures as well later on today. You can look yourself to see if this spring is correctly placed.
Unread 12-01-2009, 12:52 PM   #14
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
I'm having the same problem. Here is a link to a better picture.
http://oljeep.com/gw/82_tsm/Part%202%20Section%20A.pdf
Could someone explain exacly where the spring connects?
Thanks.
United States of America
Born: July 4, 1776
Died: Nov 4, 2008
SUICIDE
SlikRic is offline   Reply With Quote Quick reply to this message
Unread 12-01-2009, 12:59 PM   #15
jmpunited9
1974 CJ5
yep, thats it exactly. Instead of "plate" i will now call it "throwout lever" lol. Thanks for the picture. What a pain in the *** this is when trail riding, especially during frame flex over fallen trees.
